Hi it started 2 days ago, sub zero 650 fridge turns off randomly(lights go off and fridge is not cooling ). When I press start button unit works as usual. After couple of hours turn off again
It's possible that your refrigerator could have it's own capacitor/battery that needs to be charged to a certain level before every portion of your fridge functions again. You can give the fridge 1.5 hours to be plugged in before checking your freezer temperature again.
If that does not work, please call sub zero by dialing 1 (800) 222-7820
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Hi, There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
