Washing Machines Logo
Posted on Jul 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Tromm washer WM2688HWM tE error code. Very easy to remove and replaced the thermistor, BUT still, it's not working, tE error code still there. ????????????
  • Anonymous Mar 17, 2014
    cant find thermistor location
Anonymous
Level 1:
  • Contributor 5 Answers
  • Posted on Aug 04, 2009
Anonymous
Contributor
Level 1:
Answers
5
Questions
0
Helped
26973
Points
38
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
  • 4 more comments
  • David Smith
    David Smith Mar 06, 2014
    I was plagued by the TE code. It was intermittent and ultimately became a constant issue. Seeing all the comments about the wiring harness coming loose, I first accessed it through the back of the machine and pushed it together tightly. It seemed to fix the problem, but eventually came back. So, I tried one last thing before doing an all-out replacement. The connection is loose, so I got a tube of conductive grease. I pulled the wiring harness apart, filled the two female holes with a dab of grease, plugged the harness together and the problem hasn't reoccurred in three months. Very cheap fix.
  • Robert A
    Robert A Apr 12, 2014
    Yes I just did the samething Chris Perkins just said and fixed my TE code error on my LG. I pushed my washing machine on to the wall on an angle to get accesses at the bottom and checked the wirings on the thermistor connection block, didn't see any loose wire but wigged and pushed it in and turn it on and put a load of laundry. usually if I load a bit heavy i will get a TE error right away, this time no error. Thanks for the advice it saved me money.
  • Socratis Kanakas
    Socratis Kanakas May 08, 2014
    couldnt see any broken wires but error code tE was still there so i started to trace the wires and found three cut wires under the tape that keeps wire together so check full length before buying the thermistor thank you for all comments in how to find faults
  • Scott Harris Feb 04, 2018
    This was a relatively easy repair. On mine, the blue wire had come out of the connector, so I had to cut off the old connector and hard wire them together with new couplers. This involved cutting off the shrink sleeve on the thermistor, and wrapping everything back up with electrical tape. Once I did, it worked fine!
    Taking apart the washer front and putting it back together was the hardest part. The video below was very helpful in that regard.
  • DougT
    DougT Oct 15, 2018
    Scott, which video did you watch to take apart the washer front and putting it back together?
  • DougT
    DougT Oct 15, 2018
    I have the tE error and it's going to be 2 weeks until the repairman comes--I don't know if we can go 2 weeks without a washer. Also, if a part is needed, it means more time on top of that!
Brian Skow
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Dec 11, 2014
Brian Skow
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
21216
Points
I've had this happen twice now. Easy fix!
The first time I followed the AppliancePartsPros video (http://www.appliancepartspros.com/lg-thermistor-assembly-6322fr2046c-ap4445159.html) to get to the thermistor, disconnected it from the wiring connector and removed it from the washer, then reassembled. Error code gone!
The second time I tilted the washer back to gain access, disconnected the wiring, turned the thermistor back and forth while still inserted, and reconnected the wiring. Error code gone! A five minute job.
  • Eric Alfred
    Eric Alfred Feb 13, 2015
    Hey Everyone, mine was just as descride; thermistor needed to be unplugged and reseated. I am so grateful to you guys who help others like this!!!!!
    Video was a huge help.
David Smith
Level 1:
New Friend:
Problem Solver:
David Smith
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
21216
Points
Most of the time, the connection just jars loose due to the heavy shaking of the spin cycle. I fixed mine this way: disconnect the thermistor, squirt a little conductive jelly/grease into the pin holes, reconnect the jack and then tie a zip tie tightly from end to end snugging up the connection. Did this to mine a year ago and it never gave me a TE again.
Scorpiusx Woo
Level 1:
New Friend:
  • Posted on Apr 27, 2019
Scorpiusx Woo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
21216
Points
7
I have documented the replacement procedure for the LG Tromm Washing Machine model: WD-14331(6)AD, WD-12331(6)AD and WD-R8012
https://www.youtube.com/watch?v=-BrSWkasLS8&t=39s
Chris Huff
Level 3:
Top Expert:
  • LG Master 6,289 Answers
  • Posted on Oct 15, 2018
Chris Huff
LG Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017779
Points
74913
According to LG’s service information, the pernicious “te” error code is caused by a faulty thermistor. If you were just blithely to go buy a new thermistor and plug it in hoping to fix your washer, you may be disappointed. Sublime Master john63 honors us again in the Samurai School of Appliantology with his pearls of wisdom on this vexing error code:
THERMISTORS rarely fail in LG washers.
The most likey cause of the “te” error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
To access the wire plug connectors at the CONTROL PANEL—-remove the top cover of the washer.
Stand in front of the washer and look for the plug connectors behind the CONTROL PANEL. Pull apart the plugs and re-install.
Test the washer. If the “te” error still occurs—-it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely—-with good lighting. If there’s a break in the wire it will be at or near the black sheathing / heat shrink material.
Though not as common—-a broken wire at this location is *usually* caused by excessive vibration during the spin cycle. This is also *usually* found on the older LG washers that are in *wood floor* laundry rooms.
What does the code te on the LG Tromm washing machine mean?
The TE error or fault code is to indicate a defective water temperature sensing thermistor. The thermistor cannot be repaired and will have to be replaced.
Lg front load washer with a tE error code and switched the thermistor that was located when I took the top off the washer and it ran two loads fine but code is back...I noticed online they keep saying the...
As many suggest, the tE error means there is a thermistor error. On my machine, simply unplugging the machine, tipping the machine backwards (careful! ... I put a few blocks under the front legs so I could work under the machine)...and the thermistor was under the drum, with a 2-wire lead going to it. It was easy to unplug, tighten the plug (squeezing the connector), plugging it back in. The machine has now worked fine ever since this simple procedure with no failures.
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
26helpful
2answers
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Model wm2688hwm stop working screen show TE
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
4helpful
How much does a broken thermistor typically cost? My LG front loading washer is 3 years old...
THAT THING RARELY GO BAD. CHECK THE CONNECTIONS ON IT FIRST. UNPLUG AND PLUG CONNECTOR IN FEW TIMES. WHILE YOU DOWN THERE, PULL IT OUT COMPLETELY AND SEE IF IT COVERED WITH SOAP SCUM, GUNK, ETC. THAT WILL GIVE YOU FALSE READINGS AND GIVE YOU AN ERROR CODE FOR THE THERMISTOR
1helpful
4answers
LG front loader te code
A "tE" error code is more than likely the "thermistor" as CoolTech stated but fortunately it is not that difficult to service and doesn't require a technician (warranty expired for me, consider this for your own situation). It supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error...cleaned and replaced...no problems since! No screws needed to be removed. My thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center. I removed the entire grommet. It easily pops back into place. The face of the grommet and sensor appeared to have buildup from hard water which easily came off without the use of cleaners.
26helpful
9answers
Thermistor for LG WM2688H
Thanks so much for the tip regarding flipping the machine on its side. I was about do the lengthy process of disassembling the front and I tipped the machine over instead. Lo and behold, there was the problem in plain sight right away -- the wire to the thermistor had simply come off the connector! I restripped the tip of the wire and crimped it back on the connector, problem solved. Didn't even need a new part!
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
