Control panel only right side lit. Unplugged waited then plugged back in. works both sides number lit can adjust temps. then the evaporator fan stops and cannot adjust.
SOURCE: Kenmore (frigidaire) model #253.55679400 evaporator fan does not come on
yes, the fan is controlled by the pcb controller, but it is also dependent on the temperature sensor since it is waiting for the sensor to give the signal that the freezer coils has froze up before turning the fan on.
it could be a bad freezer temp sensor.
i hope i was able to solve your problem,
pls rate me
tnx 4 using fixya
drcool
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
SOURCE: Compressor starts/stops alot. Compressor is hot coils are cool
The compressor is covered for at least three years, give a call to the number listed on the owner's manual to validate warranty and get the replacement.
SOURCE: Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
SOURCE: Need Front Control Board, Kenmore Refrigerator Model 106.4410230
Solved it through parts isolation and identification.
i think left side light is not any more.... and some circut is touching each other ... i don't think so ... anyone have the answer .... you need to go for shop... Thanks..
https://watchonlineclub.com/
https://watchonlineclub.com/https://watchonlineclub.com/
