Eljer & Patriot& Elongated Toilet Bowl  Logo
Posted on Jul 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Describe your Eljer &
Describe your Eljer & Patriot& Elongated Toilet Bowl Problem.The problem is with the toilet seat.The rod holding it in place broke and needs to be replaced. I thought the parts come with a lifetime guarantee?
Fahr Quad
Level 3:
  • Master 776 Answers
  • Posted on Jul 20, 2009
 Fahr Quad
Master
Level 3:
Answers
776
Questions
0
Helped
310456
Points
2299
I have not heard of any toilet manufacturers offering a lifetime guarantee (except maybe for defects in manufacturing), especially since flappers tend to deteriorate with exposure to chlorinated water, fill valves eventually fail, and toilet seats do break. Pick out a replacement that suits your fancy, unbolt the old one from below, and install the new one. Don't overtighten as the porcelain could break.
Why does my new toilet spurt water?
There's a small clog. Plunge it until it flushes and flows freely.
Toilet is only a couple years old but gets a ring at the water line that won't come off. I have 3 other toilets in the house much, much older that don't have this problem. This one is rarely used. ...
The problem is as you said it is rarely used and the ring is from the lime build up from the water evaporating at the same line all the time. You will need to use or at least flush the toilet more often and maybe put a auto type bowl cleaner unit in this toilet. The auto unit I speak of would be a hang in or tablet type. http://www.bing.com/shopping/searchq=auto+toilet+bowl+cleaner&FORM=HURE
I do not mean to recommend on over any other.
2answers
I need a Toska toilet seat replacement
Toska seat is called Manarque seat, for the Herbeau toilet.
I searched for square toilet seat.
Site shows toilet seat for the Herbeau $135
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
http://www.faucetdirect.com/herbeau-0651-monarque-elongated-toilet-seat-with-cover-and-finish-matched-hardware/p671327?source=shz_671327&aid=228165868
Pdf from Eljer showing Tosca toilet looks very similar to product shown on links above.
1.6 gallon water-saving flush tank.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Not enough water in the bowl after flushing
I don't know what kind of toilet you have, but if it has a tank, then probably the tube that squirts water down the pipe into the bowl has come out. Take the top off the tank and as you watch, flush the toilet and make sure water is going thru the tube down into the pipe. good luck
I have 40 year old eljer toilets seat cracked,
This website appears to have what you need
http://www.plumbingsupply.com/eljertoiletparts-patriot.html
Hope this helps?
Shifting & leaky toilet
They make plates that go under the  (plastic pipe?) flange which allows one to tighten down the toilet better. Seems that your flange and toilet are not level with one another? You may need to use plastic or other shims to level the toilet before  tightening the bolts.
Top Eljer Home Experts
john h
Gene Lawson
Sean Wright
Sean Wright
Are you an Eljer Home Expert? Answer questions, earn points and help others
