Washing Machines Logo
Maritza Cruz Posted on Apr 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Portable model 44722. When spinning, why does it make a loud noise?
Michelle Balcom
Level 2:
New Friend:
  • Expert 87 Answers
  • Posted on Apr 17, 2016
Michelle Balcom
Expert
Level 2:
New Friend:
Answers
87
Questions
0
Helped
25363
Points
178
Probably out of balance. Push down on each corner and adjust until there's no wobble.
5 Related Answers
Anonymous
  • 331 Answers
  • Posted on Aug 12, 2007
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
Anonymous
  • 19 Answers
  • Posted on Nov 05, 2007
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Anonymous
  • 1314 Answers
  • Posted on Jan 11, 2008
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Anonymous
  • Posted on Sep 20, 2008
SOURCE: Maytag Performa Washer
What I found on my Maytag was the water pump went out. There is a metal ring under the pulley that fell and was grinding until it froze. Replacement is easy and can be done by anyone. You can buy a reasonable pump offline. Good luck with your repairs
Carol
Anonymous
  • 373 Answers
  • Posted on Dec 14, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ā€Ž5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
1helpful
Model # 44722 Portable Washer Are you suppose to open washer to balance load while washer is in spin? I did and the tub stopped abrutly moveing the machine about 1 foot across the floor.
a safety mecanisim built into washers is the top lid switch it detects when the lid has been opened if you do this whilst its spinning it will engage a powerful brake as you saw to stop the barrel so you dont reach in and loose an arm its perfectly normal. if the washer goes unbalanced wait turn the power off at the wall wait till it stops spinning then re arrange the cloths
best of luck
please take the time to rank this advice
merry christmas
I need permanent hook up adaptor for portable washer'Item# 02644722000 Mfr. Model# 44722' 1-847-668-3350
See the Sears Manual site for your washer.
They list a part number for converting from portable to permanent installation.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0411083.pdf
It's listed as part number 3935674.
Making loud noises on spin cycle. The whole
i have this same model and mine does the same exact thing.
Lid problem
A common easy fix for this problem is making sure the screws on the hinges (right and left side of the lid) are tight. Loose screws will cause it not to properly srike the lid switch and the unit wont run since it thinks the lid is open. If they are tight, you will probably need to replace the lid switch itself.
Loud noise
you may have something stuck on the blower wheel
3answers
Will not advance to the rinse and spin cycles...
The buzzing can only be that the pump if sticking or the inlet valve is sticking, other than that it is lack of water supply. Regards Advisor
Alexander
vince
