Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a john deere 2010. with a generator it is a pos ground when I got it someone put a alternator on it dose this change the ground to a negative
    Dedicated:
    Visited the website for 20 consecutive days.
  • John Deere Expert
  • 242 Answers
To be sure you can use a test light, touch one lead from the test light to the frame of the tractor and the other lead to the Positive + terminal of the battery if it lights up it is negative ground if not touch the negative - terminal of the battery and if it lights it is positive ground.
One thing to check if it was converted to negative ground is that the switched the wire on the ignition coil.
I have a john deere 2010. with a generator it is a - john-deere-2010-generator-pos-ground-qumruwi2utlvsp5qakcuppif-5-0.jpg Using your test light you need to turn the key to run position, touch one lead to the negative - terminal of the battery and on the ignition coil touch the Bat + threaded stud it should light and means it correct and do nothing. if not touch the Dist - threaded stud and see if it lights if it does move the wires on the ignition coil to where every wire on the Bat + threaded stud is moved to the dist - and every wire on the Dist - threaded stud is moved to the Bat +.
There is a good chance your charge gauge is backwards also , it swings in the direction the current runs and when it was reversed so did the needle on the gauge and in the case it does not mean it is discharging.
Posted on Apr 13, 2016
  • John Deere Master
  • 2,478 Answers
Most change to alt. is negative ground.
Posted on Apr 12, 2016
6ya staff
SOURCE:
Want to know if my 2010 is neg or positive grd
if this is a 60 s john deere 2010 positive ground
Dec 20, 2016 | Cars & Trucks
What is the oil filter part number for Generator engine serial number CD4045C037188?
your number 4045tf258 should be a industrial generator that number is the model number
John Deere 85 KVA 4045TF258 for sale Price 7 359 Year 2005 Used John Deere... notify john deere and use the model and serial number [i have 2 different numbers and are as follows RE506178 Oil Filter 1 RE5 9754;the first should be the new number and the other was the old ] just to make sure of the correct parts number for your unit
Aug 19, 2016 | John Deere 225 325 375 500 650 Alternator...
Whats causes my john deer 2010 gas to run onily with choke out ? Had carb rebuilt and tank cleaned. will low compression cause this?
i have seen about 4 of these have the solenoid on the bottom of the carb stuck closed was able to clean 3 out of the 4 there not cheap so try hard to clean it also had a few briggs engines have bad safety switches shut them off so check for power and ground
Jul 08, 2012 | John Deere 2010 Tractor Basic Carburetor...
Why dose my john deere ltr 180 have smoke near currung deck when i put the cutting deck down
the only thing other than a frozen pulley it could be check the routing of the belt it is rubbing somewhere.
Sep 08, 2017 | John Deere Garden
Can I jump start a john deere 445
Yes, you can jump start it with any 12 volt battery on any vehicle. Just do not have the donor vehicle running. Connect the positive cable from the donor battery to the positive post on the battery on the mower. Then connect the negative cable from the donor battery to the engine block or other ground source on the mower. Do not connect it to the negative post on the battery. Make sure you have a good connection on bare metal for the negative cable. Disconnect the negative cable the instant the mower starts.
Aug 13, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have a 3010 John Deere +24 volt pos ground how do I change from 24 volt gererator to a 24 volt altenator
The 3010 24v JD system is not a true 24v system. It is a balanced split 12v system, with one positive ground battery and one negative ground battery. The only 24 volt accessory is the starter, where the batteries meet in a series to provide 24 volts for starting. All other accessories are 12v, half powered by the positive ground battery and half powered by the negative battery. The generator charges one battery in one direction and the other battery in the reverse direction. Therefore a 24v alternator is not easily adapted to this system.
The usual solution is to change to a 12v system with an alternator, changing the starter to 12v and changing the polarity of the positive ground battery to negative ground.
The cost of a 12v starter and alternator is far less than the cost of a 24v alternator, plus the added benefit of using 12v lights and other accessories.
JD switched to this 12v type of system with alternator during the 20 series production, but used two 6v batteries in a series due to the larger cranking amp rating of the 6v batteries occupying the same physical space.
Jan 10, 2011 | John Deere 4020 Gas & Diesel Tractor...
MY CARBURETOR IS WEAR DOWNWHICH I BEEN PUTTING KITS SO SHOULD I BUY A NEW CARBURETOR FOR 2010 GAS MOTOR,it,s a john-deere tractor
Yes it is time to buy a new carberator unless you know someone who can make and install bushings in the trottle plate shaft, and choke shaft. What normally happens over time is the shaft wears into the housing as it is being used which allows ecsessive air into the fuel air mixer which causes inproper run conditions and no matter how much you adjust all the settings you cannot overcome this condition so its either get new bushings made and installed or purchase a new carberator. Hope This Helps Don
Nov 28, 2009 | John Deere 2010 Tractor Basic Carburetor...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
287 people viewed this question
Top John Deere Garden Experts
Joseph Mueller
Joseph Mueller
john h
rjivaro
Are you a John Deere Garden Expert? Answer questions, earn points and help others
