2005 Kia Sedona LX Logo
J
John reese Posted on Apr 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove heads - 2005 Kia Sedona LX
misterpj2u
Level 2:
Scholar:
New Friend:
  • Expert 65 Answers
  • Posted on Apr 03, 2016
misterpj2u
Expert
Level 2:
Scholar:
New Friend:
Answers
65
Questions
0
Helped
50991
Points
131
This must be done with the engine hot to avoid cracks, and warping
  1. Start the engine & take it for a drive so the car is warmed up properly
  2. (bottom radiator hose gets warm, & you can feel the water flowing).
  3. Drain the coolant & engine oil remove the thermostat & test / replace
  4. Remove all ancillary parts to give direct access to the valve covers.
  5. Remove the valve cover to gain access to head bolts & camshaft
  6. Turn the engine to TDC No1 on compression release the tensioner
  7. Undo head bolts in a pattern start from outside edges & work inward
  8. Remove the cam gear retaining bolt/s and support the cam gear with a piece of wire / string.
  9. Hooked the wire / string to bonnet or ceiling in garage if the bonnet is removed.
  10. Pry the cam gear off & remove the cylinder head bolts.
  11. Remove the cylinder heads, and repair / replace as necessary
  12. Reverse the removal for re-installation
willsolveit
Level 2:
New Friend:
  • Expert 67 Answers
willsolveit
Expert
Level 2:
New Friend:
Answers
67
Questions
Helped
18325
Points
198
Depends on what kind of heads you talk about.
Head gasket installation instructions for 1995 mercury mystique 2.0
NOTE: Ford does not provide camshaft gear timing marks, or information to perform timing belt service without the special tools shown in this procedure.
REMOVAL
1. Drain engine coolant from radiator and cylinder block by removing the drain plugs.
2. Remove the intake manifold.
3. Remove exhaust manifold.
4. Remove camshafts.
5. Remove valve tappets from cylinder head, then support front of engine with wood block between crankshaft pulley and front subframe.
6. Remove righthand engine lifting eye bolt, then righthand engine lifting eye.
7. Remove power steering pump mounting bracket and cylinder head support bracket.
8. Remove camshaft timing belt tensioner pulley and front cover from front of cylinder head.
9. Remove water thermostat housing from cylinder head as follows:
a. Raise and support vehicle.
b. Disconnect crankcase ventilation tube from positive crankcase ventilation valve.
c. Disconnect upper radiator hose and radiator overflow hose from water hose connection.
d. Remove water outlet connection bolts and water hose connection from water thermostat housing.
e. Remove water thermostat and seal from water thermostat, then seal from water thermostat housing. Inspect seals for damage and replace if necessary.
10. Remove ignition coil bracket from cylinder head as follows:
a. Disconnect fuel charging wiring or engine control sensor wiring from ignition coil, then ignition wires by squeezing locking tabs and twisting while pulling upward.
b. Remove ignition coil bolts or screws, then coil.
c. Remove ignition coil bracket.
Fig. 11 Cylinder head bolt removal sequence
?locale=en_us&region=region_1
11. Remove spark plugs from cylinder head, then cylinder head bolts in sequence. Discard cylinder head bolts.
12. Remove cylinder head and head gasket from cylinder block.
13. If necessary, remove lefthand engine lifting eye from cylinder head.
14. Inspect cylinder head and cylinder block, then replace components as required.
INSTALLATION
1. Reverse procedure to install, noting following:
a. Clean cylinder head intake manifold, valve cover and cylinder head gasket surfaces. Ensure flatness of cylinder head and cylinder block gasket surfaces meets specifications.
Fig. 12 Cylinder head bolt tightening sequence
b. Torque new cylinder head bolts in sequence, first to 15-22 ft lb, then to 30-37 ft lb. Finally tighten all bolts an additional 90-120° in the same sequence.
What parts have to be removed to change output speedsensor on 97 sebring convertible jxi?
Hi Nicholas, Im AL the owner of Big As Auto Repair.
FRONT WHEEL SPEED SENSOR
REMOVE
  1. Raise vehicle on jack stands or centered on a frame contact type hoist. See Hoisting in the Lubrication and Maintenance section of this manual, for the required lifting procedure to be used for this vehicle.
  2. Remove the tire and wheel assembly from the vehicle.
  3. Remove the speed sensor cable routing bracket Speed Sensor Cable Routing Brackets from the steering knuckle. Remove the wiring harness sealing grommet retainer and speed sensor routing bracket from the inner fender.
  4. Remove speed sensor sealing grommet from the inner fender Wheel Speed Sensor Connection To Vehicle Wiring Harness Then unplug the speed sensor cable from the vehicle wiring harness Wheel Speed Sensor Connection To Vehicle Wiring Harness
  5. Remove bolt Speed Sensor Head Attachment To Steering Knuckle attaching the speed sensor head to the steering knuckle. Then remove speed sensor head from steering knuckle. CAUTION: If speed sensor head locating pin has seized to the steering knuckle, do not attempt to remove speed sensor head by grasping with pliers and turning. This will damage the speed sensor head. Use only the following procedure.
  6. If speed sensor head can not be removed from steering knuckle by hand, the locating pin on the speed sensor head has seized to the steering knuckle do to corrosion. Remove speed sensor head from steering knuckle using the following procedure. Remove disc brake caliper from steering knuckle, and remove brake rotor from hub/bearing assembly. Then insert a pin punch through hole in front steering knuckle Speed Sensor Head Removal From Steering Knuckle and tap speed sensor head locating pin out of steering knuckle.
Hope this helps and please visit my auto-repair-website at:
http://www.bigasautorepair.com/
How do I remove heads on a madza mpv
Drain the coolant, remove the exhaust pipe(s) from the exhaust manifolds, remove heater hoses from heads, remove, rocker covers from the heads,remove cam belt covers and cam belt, undo the head bolts, and remove heads, this is a short version of removing the heads, but I got the feeling this job might be a little big, if you don't know for sure what you doing. special if it has to go back together as well.
How do you Remove head unit 1990 holden barina
First drain water . remove cables from plugs and any thing attached to the head. Remove valve cover, remove valve rocker. remove manifold. undo head studs , undo from the center working one stud at a time from left to right of center. lift off head.
Change head gasket on 65 mustang 200
Drain antifreeze -DON"T POUR IT DOWN A STORM DRAIN - then remove valve cover, Remove exhaust from head assembly. On this engine the head is also the intake manifold - it's cast as a unit. Remove carb and remove heater hoses from carb base plate. Remove head bolts and discard. Break head loose from block - may have to smack it a time or two to break gasket loose. Get a buddy to help lift the head off the block - it's fairly heavy. Clean gasket surfaces on both head and block. Install new gasket onto block - pay attention to gasket orientation - it goes on only one way correctly. Reverse procedure to re-install - USE NEW HEAD BOLTS! Silly to try to save $20 bucks on bolts and ruin an engine.
Pajero io 1.8 water leak at the back of the cylinder head, guide me ho to fix!
Cylinder Head Removal & Installation To Remove:
  1. Remove the intake manifold.
  2. Remove the timing belt.
  3. Disconnect the exhaust pipe from the manifold.
  4. Remove the water outlet pipe and o-rings.
  5. Remove the water passage assembly.
  6. Remove the water pipe assembly.
  7. Remove the breather hose and spark plug cables from the rocker covers.
  8. Remove the rocker cover.
  9. Disconnect the camshaft position sensor connector.
  10. Loosen the cylinder head mounting bolts in 3 steps, using the reverse of the installation sequence. Lift the cylinder head assembly and remove the head gasket.
To Install:
  1. Clean the engine and cylinder head sealing surfaces.
  2. Install the new gasket on the engine with the identification mark facing up and to the front.
  3. Using 3 even steps, torque the head bolts in sequence, to 76-83 ft-lbs. (105-115 Nm). Cylinder head bolt tightening sequence 7924ug13l.gif
  4. Connect the camshaft position sensor connector.
  5. Install the rocker cover.
  6. Install the breather hose and spark plug cables from the rocker covers.
  7. Install the water pipe assembly.
  8. Install the water passage assembly.
  9. Install the water outlet pipe and o-rings.
  10. Disconnect the exhaust pipe from the manifold.
  11. Install the timing belt.
  12. Install the intake manifold.
4helpful
How to replace head gasket 1998 Lumina
Cylinder Head Removal & Installation 3.1L Engine To Remove:
NOTE: With some minor variations, this procedure can be used on both the left and right cylinder heads.
  1. Raise and safely support the vehicle.
  2. Drain the engine coolant and the engine oil. Lower the vehicle.
  3. Remove the upper and lower intake manifolds.
  4. Remove the rocker arms and pushrods.
  5. Remove the exhaust crossover pipe.
  6. Remove the engine mount strut bracket.
  7. If removing the left side (front) head, remove the dipstick tube.
  8. Tag for identification, then remove the spark plug wires.
  9. Remove the spark plugs.
  10. Remove the exhaust manifold using the procedures found in this section.
  11. Remove the eight cylinder head bolts, then remove the cylinder head. There are locator pins that align the head to the block. Pull upwards on the head to disengage the pins, then remove the cylinder head to a suitable work area.
  12. If the head is be overhauled, remove any remaining components such as the engine lift hook, the fuel line bracket bolts, the engine coolant temperature sensor, etc., as required.
Position a new gasket, install the head, then tighten the bolts in the sequence shown (3.1L engine shown) 93173g43.gif
To Install:
NOTE: If the head gasket failed, determine the cause. Gasket failure is caused by the following conditions: improper installation; overheating due to a failure in the electric cooling fan system or a leak in the cooling system; loose or warped cylinder head; missing, off location or not fully seated locator dowel pins; low torque on the cylinder head bolts; warped block surface; scratched or gouged gasket surfaces; excessive intake manifold torque and even cracked engine block tapped holes.
  1. Clean all parts well. Remove all foreign material to the bare metal. Do not use a motorized wire brush on any gasket sealing surface. It is good practice to use the proper size thread-cutting tap to clean the threaded bolt holes in the block. This helps assure an accurate torque reading.
  2. Place a new head gasket on the clean engine block deck surface. Many gaskets will have some sort of marking denoting TOP or THIS SIDE UP. Make sure the gasket sits flat and is not hung up on the locator dowel pins. Use no sealer on the head gasket.
  3. Carefully set the cylinder head in place, using care not to damage the gasket. Make certain that the head engages the locator dowel pins that properly position the head.
  4. The bolts should be very clean since dirt built-up on the bolt threads makes it difficult to get an accurate torque reading. These are 'torque to yield' bolts which stretch a small amount when tightened; new bolts are always recommended. On a used vehicle, especially a high-mileage vehicle, it may be difficult to determine if the heads have been removed before and how many cycles the bolts have been removed and tightened. New bolts should be part of any cylinder head service. Use GM Sealer #1052080, or equivalent, on the threads of the head bolts and install all eight bolts, finger-tight.
  5. With an accurate torque wrench, tighten the bolts gradually, in sequence, working from the center outwards. Final torque should be 33 ft. lbs. (45 Nm), plus an additional 90 degrees (1/4-turn). A torque angle meter is recommended.
  6. Install the remaining components in the reverse order of the removal process.
5helpful
2answers
Torque specification on a 2003 alero cylinder heads 3.4 liter
3.4L Engine To Remove:
  1. Remove the lower intake manifold.
  2. Remove the exhaust crossover pipe.
  3. If removing the right cylinder head, remove the catalytic converter from exhaust manifold.
  4. If removing the left cylinder head, remove the engine oil dipstick and tube.
  5. Remove the rocker arms and pushrods.
  6. Remove and discard the cylinder head bolts.
  7. Remove the cylinder head.
  8. Clean the mating surfaces on the following items:
    • Cylinder head
    • Cylinder block
    • Intake manifold
  9. Clean the cylinder block bolt threads.
NOTE: During disassembly, keep the valve train components together for proper location during assembly.
To Install:
NOTE: Coat the cylinder head bolt threads using thread sealer.
  1. If removed, install the following components:
    • Exhaust manifold
    • Accessory studs
    • Spark plugs
  2. Place the cylinder head gasket in position over the dowel pins. Ensure that the THIS SIDE UP note is showing.
  3. Install the cylinder head. Cylinder head torque sequence ’99-‘00 gmpc_v6_14.gif
  4. Install the new cylinder head bolts.
    • Tighten the cylinder head bolts a first pass to 44 ft lb (60 Nm).
  5. Tighten the cylinder head bolts in sequence an additional 95 degrees.
  6. Install the intake gasket.
  7. Install the pushrods and rocker arms.
  8. Raise and support the vehicle.
  9. Install the catalytic converter and dipstick tube and indicator if removed.
  10. Lower the vehicle.
  11. Install the exhaust crossover pipe.
  12. Install the intake manifolds.
  13. Connect negative battery cable.
  14. Fill the cooling system.
How do you remove cylinder heads off of a 2002 chevrolet silverado 4.8L
first remove all ancillaries from round and on cylinder heads like exhaust manifolds inlet manifold airbox etc once you have done this remove tappet or cam cover inside these will be some large bolt heads set out along the heads in twos remove these and your heads are free but when you put it back together dont 4get new head gaskets and other gaskets
1helpful
2answers
I have I think a cracked head on my 2003 kia sorento I'm trying to find a brochure or diagram on how to disassmble a head
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Disconnect the negative battery cable.
  5. Disconnect the upper radiator hose.
  6. Remove the breather hose and air-intake hose.
  7. Remove the vacuum hose, fuel hose and coolant hose.
  8. Remove the intake manifold.
  9. Remove the cables from the spark plugs. The cables should be removed holding the boot portion.
  10. Remove the ignition coil.
  11. Remove the upper and lower timing belt cover.
  12. Remove the timing belt and camshaft sprockets.
  13. Remove the heat protector and exhaust manifold assembly.
  14. Remove the coolant pump pulley and head cover.
  15. Remove the intake and exhaust camshaft.
NOTE Keep all valvetrain components in order for assembly.
  1. Remove the cylinder head assembly. The cylinder head bolts should be removed using the 12 mm socket, in two or three steps. Clean the gasket pieces from the cylinder block top surface and cylinder bottom surface.
Cylinder head and related components
Cylinder head bolt torque sequence
To install:
  1. Verify the identification marks on the cylinder head gasket. Install the gasket so that the surface of the cylinder head identification mark faces toward the cylinder head.
  2. Install the cylinder heads with new gaskets. Do not apply sealant to these surfaces.
  3. Tighten the bolts in sequence to 75–82 ft. lbs. (105–115 Nm).
  4. Installation is the reverse of the removal procedure.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
