I bought the chair at a yard sale. My daughter has CP and the joystick is way to sensitive it turns with almost no hand movement.
There are adjustments that can be made with a programmer, a good technician can set these quickly for you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: wwe have a pronto m41 mobility chair.the service
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
SOURCE: Where can I get a manual for the Pronto M41 Electric Power Wheelchair
You can download the M41 manual at the Invacare website:
http://www.invacare.com/doc_files/1143206.pdf
