1999 Mercedes-Benz C230 Cabin Air Filter Logo
D
Doris Posted on Mar 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
For an se model daewoo matis .8 petrol. - 1999 Mercedes-Benz C230 Cabin Air Filter
Attique-ur-Rehman
Level 3:
Top Expert:
  • Bosch Master 2,677 Answers
  • Posted on Apr 10, 2020
Attique-ur-Rehman
Bosch Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
879880
Points
8007
My Daewoo Lanos would not start just turning.
Question edited for correct spelling of make and model. Question edited into written English. Question moved to make model category.
When you replaced the petrol pump, did you disconnect the battery like the service manual tells you too? If you disconnected the battery for any reason, the security system and immobilizer needs to be reset. The link between the chip in the key and the ECM has been broken.
I have an 2008 suzuki forenza and I would like to know if its has and interference engine in it
one of the most hard questions of all, given the cars history.
even the WIKI, has trouble identifying it,
no engine stated or country.? (open hood ,look up see that sticker, then engine is stated clearly there, in usa, if in fact in ,USA.
they have many, the car is a Daewoo
read the wiki
see this
1.4 L E-TEC I4 (petrol) a Daewoo variant. 1.4L
1.6 L E-TEC I4 (petrol) same Bupyeong engine 1.6L
1.8 L Family II I4 (petrol) made by HOLDEN?
2.0 L Family II I4 (petrol)
2.0 L RA 420 I4 (diesel) the wiki calls out for the 2.0Gas
X20SED D-TEC 16 Valve DOHC MPFi was built by Holden and used in the Daewoo Nubira.
but fails to note, its on a frenza.
each engine has a proper maker , and exact model number
if you dont know whats there, underhood, then no man can answer.
Firening order 2007 suzuiki forenza
usa answers.
Daewoo Lacetti in SNAKES clothing,,, what bummer car.
Daewoo failed here, now Suzuki, Double bad that...
which engines. they use many.
open hood , look up, see that EPA sticker there.
the engine type is clearly stated.
nobody here can help, lacking that.... zero.
but if 4cyl, its 1,3,4,2, (all but boxer engines)
there is the line up some are Daewoo others not.
its not the diesel. sure.
How to replace cylinder head gasket on 2005 chevy optra 5
that's a mouth fulls.
all 50 steps.
or brief?
a DAEWOO GM, monster.
1.4 L I4 (petrol)
1.6 L I4 (petrol)
1.8 L I4 (petrol)
2.0 L I4 (petrol)
2.0 L I4 (diesel)
so gas or diesel.
what country, See this, i can answer for this. USA.
the US model line features the 2.0 L four-cylinder E-TEC II made by General Motors, developing a maximum power of 132 horsepower at 5600 rpm.
Sig: I must ask questions first, I'm blind, and my tools can't reach, dig?
5helpful
2answers
Tengo tv daewoo model dtq213255e se bloqueo en la pantalla solo se ve una espesie de llave en la esquina inferior izquierda y no tengo el control remotocomo la puedo desbloquear p/n...
Problem with the Daewoo DTQ-tengo tv daewoo model dtq213255e se bloqueo en la pantalla solo se ve una espesie de llave en la esquina inferior izquierda y no tengo el control remotocomo la puedo desbloquearp/n SERIE M NOM 002 ENSABLE P-N. DMD 5404500 stmestos son los numeros que tiene en la plaquita tracera
2helpful
Se K320i mati total(power Off)
k320i watter demages dead phone please help
Daewoo Tacuma 2ltr petrol 2002
chance are you have a pinched wire in the door jam and when you shut the door its grounding out...
13helpful
3answers
Pc saya mengunakan Motherboard P5KPL-AM SE dengan prosesor intel Core 2 Duo 2,8 GHz, Memori VGEN 1 GB PC 5300, harddisk seagate SATA 250 GB 7200 RPM Pc saya tidak bisa boting dan setiap dinyalakan, 15...
Pc saya mengunakan Motherboard P5KPL-AM SE dengan prosesor intel Core 2 Duo 2,8 GHz, Memori VGEN 2 GB PC 5300, harddisk seagate SATA 250 GB 7200 RPM
Pc saya tidak bisa boting dan setiap dinyalakan, 15 detik kemudian mati.
saya juga tidak bisa masuk ke layar bios.
5helpful
2answers
Where is cam shaft sensor in daewoo matiz 1998 se plus how to change it with diagram please
cam sensor is called the optical sensor and is located in the distributer
Engine problem
did you check the ground cable for corrosion? maybe its that..... ill look into a cutoff switch for your car and get back to you asap because its a foriegn car i believe that it doesnt have a shutoff switch.
Top Bosch Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Robert Swatek
Robert Swatek
Are you a Bosch Vehicle Part and Accessory Expert? Answer questions, earn points and help others
