SOURCE: Owners Manual Needed Grand Gourmet Pro Model SG600
this is the link go get it now
http://www.kitchenmanuals.com/manuals/mfg/brinkmann/grill.html?s=gg314159&gclid=CLKQkrq2_JMCFRMJewodOCPMWw
SOURCE: Stuck Grill plates
What happens is that the upper post (see the back of the plates; there's a quarter inch wide post) slides into a slot not designed for it (too small). To fix, find the post. Slide a table knife in between the plate and the griddler, and twist. This should un-jam the post and free the plate.
SOURCE: Trying to remove service grill for Nutone QT140L combo fan/light
Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
I just bought one of these, and I'm having a similar issue. The positive terminal of the AAA battery and its associated contact point become corroded quickly. The short term solution is to use a small screwdriver to scratch some of the corrosion products off of the contact point, and put in a new AAA battery (or clean the old one). I'm going to try to clean the contacts and apply a little petroleum jelly at that spot. Hopefully, this will prevent the corrosion...
