Question about Zeiss Humphrey Atlas Eclipse 992 Corneal Topographer Topography
Humphrey ATLAS topographer- turning joystick no longer raises or lowers topographer
Turning joystick also does not lock the platform. Platform moves freely back, forth, forward and backward. It is the up, down and lock functions that are not working.
    New Friend:
  • 56 Answers
You need to replace the belt that drives the elevator gear from the joystick.
If you need help with this feel free to call or email
Andrew@premierop.com
815.325.5838
Posted on Apr 03, 2018
6ya staff
SOURCE:
Ziess /Humphrey atlas 990 servicing
You neef begin by the lowes part. You sjould rest the instrument on tje left side to get the botton screws.
In orther to take the covers you sjoul take away first the chinrest
Oct 03, 2014 | Zeiss Humphrey Atlas Eclipse 992 Corneal...
Is there an alternative seat for the Jazzy? We are trying to find a less plush seat so that the seat will be lowered enough for a Little People user. She can not get up in the seat due to disability.
Yes, this can be accomplished by lowering the seat or raising the foot platform.The cushioned van seat can be removed from the seat frame and a wood platform covered in vinyl can be substituted. Sticky back Velcro strips are put on the vinyl cover to hold the cushion. The sticky back Velcro attaches to the vinyl covered wood platform and will mate up with the Velcro on the bottom of her existing cushion. The back cushion can be left in place. Pride makes this flat platform for all their models. You would need to specify the dimensions and style of the original seat to order the custom one. There is a manufacturer sticker under the seat with a series of numbers you can give to customer service at pride to help get the correct replacement platform. You can also raise the foot platform on the vertical adjustment post or attach a foot platform to the top of the footplate.
If this modification is not covered by insurance you can have a handyman remove the cushioned van seat and hack off the cushioned foam, springs and vinyl. He could then cover the wood with a durable material or sand and paint it before reinstallation.
Hope this helps.
Feb 27, 2014 | Pride Jazzy Select 6 Indoor Power...
Zeiss atlas topographer database error
Or if it is possible make a defragmentation, you can find that tool inside of My Comp icon if you press the second mouse button
Oct 08, 2013 | Zeiss Humphrey Atlas Eclipse 992 Corneal...
Repaing the corneal topography machine atlas, humphrey zeiss
I have the same problem, the hard drive crashed. Need original install disks. Anyone have?
Mar 29, 2013 | Zeiss Humphrey Atlas Eclipse 992 Corneal...
I have a horn cabinet bought in 1987 and I can't
The old Horn lifts had vertical rails on the sides and the newer style has one center support. Push the lever up and press down on the platform to lower, push up on the lever and the platform should raise. If it binds, the plastic slides are broken or if the cables are loose, then the lift is likely broken. www.hornofamerica.com
Jul 29, 2011 | Sewing Machines
Could you please tell me how to bleed the blackhawk transmission jack. model 67554?
Jack must be filled with hydraulic jack oil. Depress the lowering valve and pump the hand pump 10 times at the same time. This bleeds the lower unit. Raise the mast until the second stage is up about 6", remove the platform mount on top and loosen the bleed screw to let the air escape. Once you have clear fluid retighten screw and replace platform. Hope this helps!
Thanks
ibuybrits
Jan 05, 2011 | Garden
Fluid head platform is moving before the fluid
Below the head where it attached to the center column is a set of three screws. Back them out a little bit and then tighten the head, then screw those three grub screws back in to lock the head.
Apr 04, 2010 | Bogen Communication Bogen Manfrotto 3046...
CX11NF "Paper Jam" and Noise
Mine use to do this, I changed paper type and it has not done it since. I was using recycled paper now I use HP All in One printing paper for Lasers and I do not have the noise.
Oct 12, 2008 | Epson ACULASER CX11NF All-In-One Printer
Zeiss Humphrey Atlas Eclipse 992 Corneal Topographer Topography Logo
635 people viewed this question
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
