v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
Normal
0
Here are all of the instructions enjoy.
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. (
3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION
SETUP MODE", the MODE LED indicator will start blinking and two
"beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button
that corresponds to the setting you desire. Directional pad UP and SELECT will
give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you
medium sensitivity. Directional pad DOWN and SELECT will give you low
sensitivity.
3. After selecting one of the above sensitivity options you will hear 2
"beeps" letting you know that the wheel has been programmed. For
Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the
specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the
completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and
hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O
and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop
blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and
brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right
Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right
Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle
button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your
wheel.
Try this link, copy and paste in google search,https://www.treadmilldoctor.com/new-bala...
