A no start when hot starts and runs good when just warm or cold no start when fully warm
There is a sequence to follow when these bikes are hot to get them started.But first.Does the bike start easily when hot if it is push started? If the answer is yes,you need to use the hot start pull switch on the carby and the get the motor in compression before you pull in the small compression lever and slowly push on the kickstarter halfway down.Release lever and fully kick the motor over from the top of the kickstarter.Don't let these bikes sit around idling.They will overheat because they need air to get through the radiator.Hope this helps
Hi Roland Border,
Is the engine Overhead Valve ? Spark plug wet or black ? or is it dry
