Nostalgia Electrics MOS-400 Counter Top Margarita Oasis Frozen Drink Machine, Blend Shaved Ice and Favorite Mix for Frosty Tasty Smoothies & Daiquiris Logo
Cheryl Platamone Posted on Feb 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I lubricate the ice shaver rod-it squeaks and with what kind of lubricant?
Rabbit Brains
Level 3:
  • Master 575 Answers
  • Posted on Feb 29, 2016
Rabbit Brains
Master
Level 3:
Answers
575
Questions
Helped
182479
Points
1598
If you can visually see the rod, use a few drops of cooking oil. If it leaks into any drink, you wont get sick. Don't use mineral oils.
Model BFP-703. Why can't locking ring be removed?
Some lubricant might make removal easy.
The cover with large feed tube is stuck. how can i get it of
So frustrating when that happens!
Use some PAM vegetable spray or something similar under the rim. Try to keep it lubricated in between uses (like, spray in with PAM before you store it, or right before you use it again)
How to lubricate blade assembly.
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
How much will the coarse blade part cost
Amazon.com 1 cross blade 2.50 plus 3.93 shipping
Amazon.com 2 cross blades 8.49 free shipping
Amazon.com 1 ice shaver blade 3.91 plus 4.99 shipping
Food processor is leaking oil
There is next to no oil in a food processor. Sure the top bush/bearing is lubricated with oil but gravity does not go up no matter where you are from.
2helpful
Margarita mania MMA-600
We are under new management.
Please call 1-920-347-9122 and we can help you with your request. Our new website is www.nostalgiaelectrics.com .
We are more than happy to help!!
Rival ice maker
plz cont - 23051554 \ 23095757
Jul 26, 2008 • Blenders
3helpful
Margaritaville Frozen Concoction - Ice shaver has stopped turning
On my machine (DM1000) there is a kill switch on the top & back of the ice reservoir. If that gets broken/misaligned the shaver will not activate.
Top Nostalgia Electrics Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Nostalgia Electrics Blender Expert? Answer questions, earn points and help others
