SOURCE: what's the difference between Easybase (non
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
SOURCE: Is the maxi cosi cabriofix car seat compatible
I just called the Maxi Cosi customer service line to ask this question. No, the carseat base for mico will not work with a cabriofix carseat- different shape.
SOURCE: We have a cabriofix car seat on a family fix base
Get back to where you bought it for a replacement - these things HAVE to work perfectly to keep your child safe - don't try to "fix" it you could live to regret it.
PLAY SAFE
SOURCE: Our car doesn't allow us to use the easyfix
The carseat has obviously not been correctly installed using the seatbelt as it cannot be removed without undoing the seatbelt if it has been correctly installed. Contact your retailer for a demonstration on correct fitting.
