Electrolux Ewf1090 Front Loader Belt Part No:1323531309 Logo
v
vk2ast Posted on Feb 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine stops on rince cycle
The machine washes till it comes to the rince cycle and stops the timer counts down to 1 minute and sits doing nothing. also the machine seems to get out of ballance in the spin cycle is there a circuit diagram as it looks like there must be a out of balance sensor??
mj mj
Level 2:
Sergeant:
  • Expert 192 Answers
  • Posted on Feb 24, 2016
mj mj
Expert
Level 2:
Sergeant:
Answers
192
Questions
Helped
49882
Points
554
When the unit sense a strong vibration it automatically stop the unit. unplug the unit and wait for thirty seconds then open the lid and redistribute the cloths inside to balance the load then close lid then plug unit then push power and program your washing again
2 Related Answers
BIKER T
Terence Fourie
  • 909 Answers
  • Posted on Sep 05, 2010
SOURCE: Hi, I have an Electrolux
Im taking it that you have a squirrel cage motor.(motor without bruhes) Locate the capacitor and replace it. Most of the time its the capacitor that has malfunctioned and that will stop the spin cycle. If you have a soft start.(an electronic control), then check the brushes. Possibly need someone to help as the motor will need to be removed to gain access to the brushes. Check length. must be at least 25 mm.(otherwise not enough tension). Make sure power is pulled out when doing this repair.
Anonymous
  • 2382 Answers
  • Posted on Oct 13, 2010
SOURCE: Electrolux EWF1087 washing machine that
Hi, you most likely are getting a "RPS Sensor Fault"
When the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed if it does when your washer faults out matches exactly with the RPS fault code.
Ewf1090 washing machine stops at the rince cycle and stops the timer just counts down to 1 minute and never completes the cycle
problem program board or switch system
have a technician test / replace problem board / switch
Whirlpool washer bad timer
it very much sounds that the moving parts the timer are worn or seize recommend new timer
3helpful
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • 33helpful
    2answers
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    2answers
    Inglis Washing Machine agitator not working right
    washing machine will not aggitate will do the rest
    Top Electrolux Washing Machines Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
