Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
A
Anonymous Posted on Feb 23, 2016
What does fisher paykel fault code f0 mean? - Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Pete
Level 1:
Habit-Forming:
  • Contributor 36 Answers
  • Posted on Nov 21, 2016
Pete
Contributor
Level 1:
Habit-Forming:
Answers
36
Questions
0
Helped
28267
Points
45
Faulty freezer temperature sensor - this would be for an older model fridge
1 Related Answer
sonicboomele
sonic boom electronics
  • 1557 Answers
  • Posted on Jul 11, 2011
SOURCE: What is fault code 2
The resistance of the Evaporator Sensor is outside of the normal range (> 45k ohms).
Primary Action
- Check sensor connection at controller.
Secondary Action
- Replace sensor.
1helpful
2answers
I have DW60CDX2 , Turning on but buttons are not responding when I pressed buttons?
from what I'm seeing for the dishwasher, an E1 error means that the door is not properly closed. So, please look at the door of the machine to make sure that nothing is broken or that the dishwasher isn't too full. Thank you.
I have a fisher Paykel dishwasher and a e20 code came up does this mean it is blocked
Hi Vivianne
I found the definition of some error codes but I don't know if any of these will apply to your appliance:
Fisher Paykel Fault Codes
I hope this helps
I have a fault code 249 from my Fisher and Paykel 8kg washing machine. What does this mean?
I didn't know the codes went this high! it will be a motor controller fault I would suggest, as all other faults above 140 are motor controller.
2helpful
On a fisher & paykel washing machine what does it means by fault code 12. The washer is approx 8 years old.
Hi just read posting.Error code 12 means FLOOD PROTECTION ERROR.Has you machine overflowed or does not pump the water out quickly?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
4helpful
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
3helpful
Fisher and paykel diswasher f1 fault code
f1 fault code means the flood switch is activated. There is moisture at th e base of your dishwasher.
4helpful
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
2answers
Fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
2helpful
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
