SOURCE: Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will
flush and pump out for 5 min and restart on its own..This is caused by
too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
SOURCE: F1 error code on Kenmore Oasis He
After getting the F1 error on my model 110.27086601 and looking at other posts here & elsewhere, I made one call to the "Product Resolution Center" at 800-847-9083 on 4/9/10. They answered quickly, looked up the model & serial number I gave them (begins with CT18) and confirmed that the unit is covered under the "upgrade plan" (as opposed to calling it a recall). They are sending the part directly to me today and they scheduled a Sears tech to come install it in 10 days (or less if the part arrives sooner). The part, shipping and service call are free. The whole call took less than 5 minutes and was no more difficult than ordering a pizza. The agent was polite, professional and a pleasure to deal with.
I'm pleased that 2 years after the warranty expired they are providing this repair free of charge and without any hassle.
To those who have had problems when calling or who will be calling, may I offer this tidbit for dealing with any customer service contact? Be polite and businesslike. The agent on the other end doesn't need to hear about "how disappointed you are, blah, blah" or that you've "been a loyal customer for 84 years" and you've "never had a problem like this" or any other editorial commentary - just be friendly, and say something like " Hi, I have an Oasis washer with the F1 problem and I understand that there's a recall covering this." That's exactly what I said and the agent efficiently handled everything from there.
Remember, the agent gets measured on the number of calls they complete so they just want to take care of you as quickly as possible. Help them by just simply stating the problem and just answering their questions with just the information requested. They are not there to listen to people whine - they've heard everything you have to say a thousand times and they will appreciate your brevity and no nonsense demeanor. Make it easy for them and they'll make it easy for you. Do your venting here if you must.
Hello protocolu898 - Do you want to know how to display an error code on the washer? Or do you have an error code do you need assistance with?
Hi - Are you certain the error code is L7? This manufacturer does not have any L7 error codes for any washer or other units. I understand that it will not spin either; does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
