Juicers Logo
C
Colleen Jackson Posted on Feb 22, 2016
Can you unscrew the basket of a juiceman II if placed on the spinner before the housing unit?
Fran B
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 09, 2019
Fran B
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
680
Points
Did you ever figure it out? Because I just did exactly THAT!! Arghh! Would love to know if you've found a solution. It's been such a long time and I started putting it together before I found all the parts and now can't for the life of me remove the basket!
  • Dorie Pride
    Dorie Pride Mar 15, 2021
    I did the same thing!!! What is the solution?
How do I disassemble a Juiceman ll?
Search Results
    How to Use the Juiceman II Juicer Instructions - YouTube
    ? 12:57
    www.youtube.com/watch?v=sQgtIojaeVk
    Feb 1, 2012 - Uploaded by DiscountJuicers.com John from http://www.discountjuicers.com/ explains how todisassemble, assemble and juice with the Salton
2answers
How do i get the screen filter out of juicer
I had the same problem with my Salton juicer, after making a delicious juice it was almost impossible to remove the auger like many of you, with patience and lots of elbow grease I manage to take apart. Here is my solution to this problem and it works very well for me, its simple, before juicing, disassemble your juicer and add a little oil with your finger on the silicon seal (inside and outside) see picture attached, assemble the juicer.
After juicing, remove the cover, don't try removing the auger, instead grab the basket and wobble it and it should get free, it works for me and it should work for you too. Happy juicing to all!
Manual for juiceman 2
Keep in mind that this item has been discontinued; however, you can find some details in this links:
- Juiceman II Elite - User Guide
- Juiceman II Elite J411 - User Guide
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice weekend.
Nov 18, 2011 • Juicers
1helpful
2answers
Need a juiceman 11 juicer instruction manual.
I have a manual for the 211, let me know if you're interested and I can scan it.
Ican not remove the the basket for cleaning is to hard
You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
3helpful
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
25helpful
4answers
Unable to take juiceman apart to clean
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Tom
1helpful
Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
4answers
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 • Juicers
Top Juiceman Juicers Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Juiceman Juicer Expert? Answer questions, earn points and help others
