Contixo Kids 7-inch Tablet Touch Screen Android 4.1 Dual-Cameras Wifi Blue Logo
Posted on Feb 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on the tablet about 1/4 on the right is gray with lines in it and the other 3/4 is normal and it is not coming on.
I am not getting any pictures. What is broken?
L Pfaff
Level 3:
Top Expert:
  • Contixo Master 11,573 Answers
  • Posted on Feb 21, 2016
L Pfaff
Contixo Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3584891
Points
181713
Yve, probably the screen needs replaced.
My 7inch tagital tablet shut off and wont turn on I try charge but it still not coming up.its not even a month since I have it
what usually cause the problem of most tagital tablet not turning on
is when the battery is over charged.the maximum time to charge a battery is six hours when bought new.if you dont it will pose some difficulties later.
there are three options
1. get another battery
2. get a booster to boost the battery
3.you also use LED by pinning its cable to the battery,this will take some time.then wait until the light on the LED goes off.it normally takes 3 days before the LED light turns off.
if you have taken these steps the next thing to do is to put the battery back on your tablet and connect it to a power source i mean electric current and see if it will respond to charging.if it works, then you got your tablet back,but if not please get a new battery.thanks
1helpful
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Turn off data on my tablet
I don't know your tablet, but it's generally an options in settings. The settings icon is a sort of gear shape.
My tablet doesn't have color,and all that comes up is just a box and the picture is gray
I'm sorry for the rude & unhelpful man before me.
I will help you.. But first I need to know:
1) which laptop you have. ie: HP, IBM, DELL, etc.
2) model name ie: thinkpad, latitude, pavilion, etc.
3) model number
4) operating system ie: windows7, 8, 10, etc.
Ok?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/lynn_f08552ff80c75888
How to factory reset a hkc tablet model number a072d
Try this
1.hold down the power key for 10 seconds to turn off the unit with nothing hooked to the unit (no ac/no usb/nothing)
2. hold the volume up key (+) and the power, once the screen starts to turn on release the keys.
3. NEXT you should get a robot laying down with a red triangle, push the power key one time. This will get you to the menu screen.
4. from here you chose the reset factory by using the volume down (-). Once you have that line highlighted press the power button.
5. next use the (-) key to get to yes to reset/reboot followed by the power key to chose the option.
6. tablet will come back on and be just like you got it from the store originally.
How to get 50 preload apps
Reload the original system files
1.) Download the "system.zip" file and unzip (using a program such as WinZip, 7-Zip, WinRAR, etc.) the file.
2.) You will then need to connect the Tabeo tablet to your PC and then select the "Turn on USB storage" option on the screen once it comes up.
3.) After the file has been unzipped it will need to be transferred to the main folder, or "root directory" of the Tabeo tablet. Please ensure that you do not place the "system" folder in any of the folders already in the "root directory".
4.) You will now need to have to go into Settings application (located under the apps list from the top right corner) and go down to "About tablet" and select Start Wizard. Then turn the unit off and on again.
5helpful
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
VGA port connection to old style TV
Right click an empty spot on your desktop, select properties. Click the Settings tab. Right click the gray-ed out monitor, select enable.
To push the image to that screen, press the Function (FN) key and F4 normally.
Top Contixo Tablets & eReaders Experts
ADMIN Eric
ADMIN Eric
john h
ADMIN Andrew
ADMIN Andrew
Are you a Contixo Tablet and eReader Expert? Answer questions, earn points and help others
