Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
The remotes use a receiver to actuate the door and the wall control does not. It sounds like your logic board is bad. Maybe a lightning storm recently? Try removing the board and look for burnt or missing traces on the printed circuit.
The sensors have nothing to do with your door opening. First thing to check are the door springs. One may be broken. Next remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It may be stripped.
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Most likely you have a broken door spring. Look closely as sometimes it is hard to tell. Also remove the cover and look at the drive gear. It is white nylon and is just in front of the motor.
