Jenn-Air JED8430 Electric Cooktop Logo
A
Anonymous Posted on Feb 17, 2016
Jenn-Air JED8430adb downdraft radiant Cooktop tripped the breaker and the breaker won't reset
While cooking on the cooktop, there was a loud pop and it shut off. We tried the breaker, but it won't reset. We checked to see if breaker was bad, but the problem is not the breaker. Don't know where to start?
Level 3:
  • Jenn-Air Master 19,187 Answers
  • Posted on Jun 04, 2016
Jenn-Air Master
Level 3:
Answers
19187
Questions
0
Helped
4345042
Points
82261
5 Related Answers
Anonymous
  • 59 Answers
  • Posted on Jun 26, 2008
SOURCE: exhaust fan not starting
Hi
I have all the diagrams for that model and will gladly send them to you all for free via email. Remenber that the fan will always get gresse and have to be clean, also keep the filter clean.
Let me know were to send the diagrams...Glad to Help!!
Eddie Rentas
Tupper Lake NY
Anonymous
  • Posted on Nov 30, 2008
SOURCE: downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Anonymous
  • Posted on Apr 15, 2009
SOURCE: Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Anonymous
  • 15935 Answers
  • Posted on Apr 29, 2009
SOURCE: Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Anonymous
  • 530 Answers
  • Posted on Sep 21, 2009
SOURCE: electric shock from cooktop, didn't trip breaker,
Where did you smell the smell was it from the fan switch. turn the power off and take the screw out of where the fan switch is and check the wires to the switch and the switch itself. sometimes the jennair cooktops have issues with that switch. let me know how it goes
Can I remove the downdraft equipment under my jennair electric cooktop and still use my cooktop?
It is possible to remove the downdraft equipment from underneath your JennAir electric cooktop and still use the cooktop, but it depends on how the downdraft equipment is attached to the cooktop and whether there are any other issues that may arise from removing it.
Before attempting to remove the downdraft equipment, you should consult the user manual or contact JennAir customer service to ensure that it is safe to do so and to obtain any specific instructions for your particular model.
Some potential issues to consider when removing the downdraft equipment include:
  1. Airflow: The downdraft equipment is designed to help draw smoke, steam, and odors down and out of the kitchen. Without it, you may experience reduced airflow and ventilation, which could result in lingering odors or smoke.
  2. Heat distribution: The downdraft equipment may also help distribute heat evenly across the cooktop surface. Without it, you may experience hot spots or uneven cooking.
  3. Stability: The downdraft equipment may provide additional support or stability to the cooktop. If it is removed, the cooktop may become less stable or secure.
If you decide to proceed with removing the downdraft equipment, it's important to follow all instructions carefully and to take appropriate safety precautions. You should also be prepared to address any issues that may arise as a result of the removal, such as by using an alternative ventilation system or adjusting your cooking techniques to compensate for any changes in heat distribution.
If you're unsure about whether or how to remove the downdraft equipment from your JennAir electric cooktop, it's best to consult with a professional technician or contact JennAir customer service for guidance.
Nov 29, 2022 • Cooktops
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
[email protected]
406.471.0000
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Electric shock from cooktop, didn't trip breaker,
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
2helpful
2answers
CLICK HERE
1helpful
Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
