Drills Logo
A
Anonymous Posted on Feb 16, 2016
Can I replace my defunct Makita charger dc1411 with a dc1413/4?
mj mj
Level 2:
Sergeant:
  • Expert 192 Answers
  • Posted on Feb 24, 2016
mj mj
Expert
Level 2:
Sergeant:
Answers
192
Questions
Helped
49851
Points
554
Check the detailed power outputs ,if they are almost the same voltage and milliamp output. then you can use dc1413. usually they are almost the same specs
REPLACEMENT CHARGER MAKITA DHP 456 18V 4.0AH LITHIUM-ION
Here is the charger. it is priced pretty good. I have seen it at other places for over $100.00 https://www.factoryauthorizedoutlet.com/makita-7-2v-18v-pod-style-and-stick-style-3-hr-charger-model-dc1804
10helpful
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
2answers
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but...
You can get a 18V replacement Makita battery for your drill. The replacement one is cheaper. Replacement MAKITA BL1830 battery pack 100% compatible with the original BL1830 battery, high quality, wholesale price.
http://www.drillbattery.com.au/buybattery.php/makita_BL1830_power+tool+battery.html
17helpful
3answers
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
3answers
Makita Battery Charger DC18 RA
Maybe your battery is died, you can replace it on
http://www.drillbattery.com.au/buybattery.php/makita_1220_power+tool+battery.html
Jan 20, 2009 • Hand Tools
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
