I ran another wash and now it stops w/ 71 mins. remaining. When I try to restart it, nothing moves and it is making a kind of grinding sound.
SOURCE: Sears Kenmore Elite Front Loader Washer F09 Error 110.42832 200
Okay...you probably already know this, but here it goes. F9 is an Overflow Condition. If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following: 1. Check the drain hose and make sure it is not plugged or inked. 2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU). 3. Check/Clean Drain Pump Filter of foreign objects 4. Check for Drain Pump Failure. 5. Check the Inlet Valve for proper shut off 6. Check the Pressure switch for proper operation. Now, I don't know if the repairman had anything to do with this problem or not. If he didn't mess with any electrical connections, then this may strictly be coincidence. If you've only been checking the drain pump for foreign objects, you probably need to check some of the other items mentioned. 1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. Could be you have an obstruction somewhere. Be sure to check the hose just prior to the drain pump as well. This is the hose on the bottom of the tub. This area can get clogged with debris. (Also, to prevent from making a huge mess the next time, try using this procedure to drain the washer from the machine BEFORE you remove the pump cover). 2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the rear of the washer with all the wiring running to it). Could be you have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. I don't know if this will generate an F09 error, though. 3. The drain pump. If it's running and you've already checked it for foreign matter, the pump is probably not the problem. 4. The inlet valve. You can check them if you like, but an overflow condition would indicate the presence of too much water. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time. Could be running water or a small trickle. Do you find standing water in the tub when not in use? 5. The suds error. This occurs when air from too much detergent gets into the drain line. I know you say you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider: a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use. b. Look at the detergent container. Is it double concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds. c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing. Rule out the simple common sense things first. When everything else checks out and your problem still persists, you may have some concern (usually the CCU or pressure switch). I hope I'm not insulting your intelligence, and I hope this helps you in some way.
SOURCE: Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem.
worse case scenario is the transmission is bad, but this is unlikely.
SOURCE: Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
SOURCE: F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
SOURCE: series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
