Tried soft reset didn't work. Tried inserting different Sim card and it still didn't read it.
Samsung Galaxy Mega 6.3: SIM card not working:
Hello. sometimes the SIM card slot gets loose over time.
If you notice that it is easy for the SIM card to slip in and out of the card holder.. or if not you can try this fix anyway to see if it helps:
You'll need some scissors and some clear tape like scotch tape..
cut off a very small piece of tape just enough to cover the top part of your SIM card..
it doesn't have to cover the whole top part..
It can not cover any connectors..
after affixing, slide the SIM card back into it's holder to see if that works..
If that doesn't help, you may have to visit your local Service Provider's store to get a new SIM card
http://forums.androidcentral.com/verizon-droid-dna/276699-sim-card-improvement-maybe-not.html
SOURCE: Samsung SIM card issues!
you dont have to buy new sim...go to your nearest service senter. hardware failure.... sim sockets or sim ic... thats the problem...
SOURCE: i think my phone got reset. cant unlock phone and voicemail stop
samsungs default factory code is 12345
SOURCE: I changed sim card, now they both display ''Insert SIM''
try taking out both cards and popping the battery on the phone.
Wait a few minutes and then turn the phone on with no card in it.
Turn it back off when it says no card found and insert the newer card and power it back up.
It seemed to keep a memory of the blank card.
SOURCE: Phone won't read sim card
try this tricks.
1. get a pencil eraser.
2. take out your sim from your phone.
3. use the eraser by rubbing the surface of the contacts of your sim.
4. get some clean and soft cloth and wipe the contacts of your sim
and insert it back to your phone,
5. restart your phone.
or you may do one of these for trouble shooting.
1. get another unlocked phone and have your sim inserted there and
check.
***** if the other phone doesn't read your sim then replace it with new one or take it to your nearest network provider office and have it checked.
2. get another sim and insert it to your phone and have it read by your
phone.
***** if the other sim can't be read by your phone, bring your phone to your nearest service center and have it check, it can be a hardware failure.
SOURCE: When I insert another mobile
It may because of the Network Lock.,You need to Unlock the Mobile Phone from the Network Lock,You Can get the Unlock code at reliable cost at here
http://www.mobileunlocksolutions.com/samsung-s3650-corby/rs1wp9/ and Unlock the Phone....
