New switch worked for a few seconds. tightened all the screws and now nothing
Use your flathead screwdriver to pry off the plate on the left side of the elliptical trainer.
Step 2
Look for the magnet and reed
switch. These elements will be roughly the same size, and the reed
switch should have a series of wires connected to it.
Step 3
Loosen the screw in the reed
switch using your screwdriver. Move the reed switch by hand until it
sits 1/8 inch from the magnet, then re-tighten the screw.
Step 4
Test the unit to see if the
display and heart rate monitor are working properly. If not, move the
reed switch slightly so it is closer or farther from the magnet, then
try the machine again. Once you've found the correct location for the
switch, tighten the screw to hold the reed switch in place.
Step 5
Replace the cover plate by snapping it into position by hand
God bless you
