SOURCE: IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
SOURCE: whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
SOURCE: Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in
it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let
it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
Testimonial: "Good trouble shooting tips...will give them a try and see how they go, THANKS!"
SOURCE: Does the ice maker lever suppose to be up or down
Down. It can take up to 24 hours for the first ice to be made on a new installation. Longer if there is a large in line water filter and it was not purged during installation. Additionally... if there is an automatic defrosting problem with the unit it may not make ice at all. The freezer has to be less than 16 deg F to make ice. If you need more assistance just respond to this post and I will gladly help you. If you need unit specific data PLEASE include your model number in any reponse.
Thanks for choosing FixYa.
Kelly
