Search Results
whirpool f21 error code - YouTube
? 3:04
https://www.youtube.com/watch?v=b24PVv-ORqg
Jul 1, 2012 - Uploaded by davidmontabon
whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
My maytag 5000 series steam washer stopped and said Sud ...
www.fixya.com/support/t8682656-maytag_5000_series_steam
Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Hi
F21 error means that the drain time has exceeded 8
minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to
clear the display. If errors still remains then please check the drain hose and
make sure it is not plugged or kinked. Disassemble the washer by removing the
back from the washer and check the electrical connections at the pump and make
sure the pump is draining. Also inspect the pump filter for foreign objects.
Before disassembling remember to turn off the power and disconnect the washer.
If it still doesn't help then there is an issue with the pump and you'll need
to replace it. Hope this helps... Please post back if you need more
information.
Daniel
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable
to drain, press PAUSE/CANCEL button twice to clear the display. After this
please check the drain hose and drain pump filter for any blockages and make
sure it is not clogged with foreign particles. You can also check the drain
pump to verify that its working. Please get back to me if you have any other
questions.
Kevin
