ASUS K50IJ-C1 Notebook Logo
Lenette Willis Posted on Feb 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why doesn't it turn on? - ASUS K50IJ-C1 Notebook
David Payne
Level 3:
Top Expert:
  • ASUS Master 14,162 Answers
  • Posted on Feb 09, 2016
David Payne
ASUS Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998006
Points
455836
2004 Ford Taurus won't start?
get your battery checked
DVD recorder doesn't work
what is the problem, doesn't turn on or doesn't record .
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
2002 Dodge Caravan,3.3L,Engine won't turn over at the key.Battery,starter and relay are good.Relay doesn't function when plugged in.It has 2 feeds.If you run a ground to the ground side of the...
It has 2 feeds.If you run a ground to the ground side of the relay,engine turns over but doesn,t run ????? The PCM - engine computer isn't supplying the ground for some reason . Anti-theft system problem . Disables fuel an starting systems . Have you checked for codes ?DTC'S - diagnostic trouble codes .
When I turn on my Canon ir 1018 it doesn't stop heating. i.e it doesn't get ready for photocopying. It keeps on turning but doesn't stop in order to get ready.
This sounds like a faulty fuser assy. Basically the machine is warming up but nevers gets to temperature. The lamp has probably blown and for some reason it is not giving any error.
I would put a new fuser in and all should be well.
2helpful
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
4helpful
My 1993 corvette wont start
Car doesn't turn over,but ignition turns on? Doesn't happen all the time,it just happens.. If I let it sit for a while it all of sudden turns over and starts. Happened twice this year..
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
