My suggestion , would be to find a lawn mower repair shop (that's not too busy out of season) and nicely ask the attendant to make you a new brake , believe it or not , lawn mowers use a lot of similar things that strollers do (wheels, cables,tubing ,Etc.), and chances are they can with a bit of time make you something to work from what they have lying about . as this model is as you said .discontinued and no new parts are available
SOURCE: broken harness on bugaboo frog
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: [email protected]
WEB SITE: WWW.BUGABOO.COM
SOURCE: Bugaboo Frog Foam Handle ripped
On Ebay, if you type in Bugaboo on the search field, there is an item called Stroll-air that covers the handle bar. I think it's made of neoprene (like wetsuits) or something that looks like it.
SOURCE: broken brake cable
Just had our Frog brake cable replaced by the local bicycle repair man. It cost £5 and took 20 minutes!
SOURCE: Bugaboo Parts - where can I buy a replacement handle bar / carry handle?
You should purchase your accessories direct from www.Bugaboo.com
email: [email protected] or call 1-800-460-2922. This way you can make sure that you don't void your warranty.
Good Luck! from Moms Just Know
SOURCE: bugaboo frog hood
you have to check out www.myhoodbaby.com for replacement hoods for bugaboo! expensive but ohhhh so posh!!!
