The crossman phantom is a spring powered air rifle which means that you pull the barrel down through the arc of its travel until the piston locks up to the trigger mechanism in one continuous movement
depends on the model:
There are two ways to upgrade the iOS
- via connecting the device to iTunes on a computer
- or directly from within the device, but only snce iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
will engine start if u spray carb cleaner or start fluid in air intake hole ,?? if it wount then all the fuel pressure in the world wont fix an ing problem .
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
on a iPhone 3 it is not possible to install iOS 6 !
IOS 6 is possible only on iPhone 3GS / 4 / 4S
- There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
look at page 17 here is all the install instructions plus troubleshooting
x air conditioner/heat pump
operates at reduced
performance.
x Air conditioner/heat pump
operating at low stage when
expected to operate at high
stage.
x Integrated control module
diagnostic/status LED's display
the indicated code http://www.alpinehomeair.com/related/IO-348K%208.2013.pdf
Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
