If it is a top loader machine with an agitator that stands up in the center of the tub, try removing the dispenser and lint trap from the center ( normally just a pull up) and right down the bottom there is a 10 or 12 mm bolt that you undo and that allows you to pull the agitator up off the drive shaft
talk with a service agent as to how to get the agitator out or down load a workshop manual from google by typing in --workshop manual for hoover model 201m washing machine -- and if there is a pdf version then down load it
SOURCE: hoover 800 washing machine
take the cap of the top of the agitator you need a 10mm socket
on along extension bar undo the bolt in the bottom of the agitator and it will lift out replace by do-ing the reverse process
i have just done it better than paying $100.00 for a service call
for five minutes work
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
SOURCE: Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
SOURCE: I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
SOURCE: Need wiring schematics for Hoover 750L washing
www.washerhelp.co.uk/diy-repair-help_4.html
www.washerhelp.co.uk/diy-repair-help_3.html
These sites above will help; Yo get a Schematic, you need a service manual, I was unable to find one for your model.
http://appliancejunk.com/forums/index.php?topic=2846.0
This link above, has "Generic" manuals, download one of them, you will find a schematic diagram, of a generic, circuit, they are all pretty much the same, in the add on's to the "Control Board" It will be helpful in tracking any faults, also inside the manual is troubleshooting tips, that apply to ALL, they will help you narrow it down.
Always check, hoses, pump, filters.
might be your drain pipe is too far down the drain tube, take out your pump and clean it.
Check the pump the spade connections , might be a bit loose.
This COULD be a clutch problem. Pads sound like they are gone. If its over 5 years old it will be better to replace. And throw-out bearing in a washer? there is tub and clutch shaft bearings; but it takes quite a bit of experience and tools to change.
good luck and consider shopping around. It is always best to get an Engineer.
