must have somthing in tank tack off clean it out real good chang fuel finter claen carb out blow lines out reinstall tank put fresh gas in not old gas check fuel pump when priming it thats about all you can do shoud be under warranty
if by turn you mean they wont rotate, then check if parking break is on, if you mean you cant turn the steering wheel, or cant make make it go around corners, then check the linkage
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
SERVICE REMINDER/HOUR METER Service reminder shows the total number of hours the engine has run and flashes to indicate that the engine or mower needs servicing. When service is required, the service reminder will flash for two hours. To service engine and mower, see the Maintenance section of this manual. NOTE: Service reminder runs when the ignition key is in any position but "STOP". For accurate reading, be sure key remains in the "STOP" position when engine is not running.
You likely have a tail light in the rear that has a filiment dropped to ground allowing the relays for the lights to stay on there by by- passing the switch.Remove both rear tail light bulbs and start the tractor,all should be normal,if so ,then you just need to put in new bulbs.If this does'nt work then you need to check you light relays,one of them has failed.The operaters can tell you where to find the and which one runs what.Good luck
