SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
