It has 2 feeds.If you run a ground to the ground side of the relay,engine turns over but doesn,t run ????? The PCM - engine computer isn't supplying the ground for some reason . Anti-theft system problem . Disables fuel an starting systems . Have you checked for codes ?DTC'S - diagnostic trouble codes .
This sounds like a faulty fuser assy. Basically the machine is warming up but nevers gets to temperature. The lamp has probably blown and for some reason it is not giving any error.
I would put a new fuser in and all should be well.
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
Car doesn't turn over,but ignition turns on? Doesn't happen all the time,it just happens.. If I let it sit for a while it all of sudden turns over and starts. Happened twice this year..
