Whenever you go hiking it important to bring map with you Ideally this will be topographic map which is the kind with the squiggly lines on it Called contour lines they can tell...
May 29, 2011 - Navigation map DVD disk read error - Suzuki 2007 XL-7 question. ... The only correction I've seen for this problem is to replace the radio itself. ... Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time ... Navigation system at Yukon xl 2008does not read the map DVD.
A barometric altimeter can be used with a topographic map to verify one's location and it is often more reliable than a GPS. However, barometric pressure changes with weather, therefore hikers must recalibrate their altimeters every once in a while, when they reach a known altitude like a trail junction or a peak that is marked on the topographical map.
The Garmin "GPSMap 295" is at, as far as Garmin is concerned anyway, "end of life". This means Garmin will no longer support, repair, etc. this product. C'est la vie.
Garmin's older product lines lack the hardware to decompress the new "NT" (New Technology) maps that Navtek (the map company) is producing now. The NT maps are compressed so that they would fit on smaller capacity memory cards. By doing this, the maps required Garmin to include hardware (special designed circuitry) that could quickly decompress these maps "on the fly" for display. The much of Garmin's older GPSMap & StreetPilot lines predate this hardware requirement.
Our "still-functioning" GPSMap & StreetPilot GPSr will still pinpoint our location on the Earth as always - but lack the latest & greatest maps. You should review the maps that your GPSr can use and choose the one you prefer. I switched mine to display topographical maps. These show many of the road names like the City Navigator maps do, but lack important things like the POIs and routing. If you can do without them, this could be good enough. If you can't, you'll need to decide on whether the last non-NT map version is sufficient or purchase a new GPS that can accept the maps you want to put into it.
tap on the wrench, tap on map, tap on about map, there you should see the base map checked, and the Europe map unchecked, uncheck the us map and check the europe map by tapping on the check box. leave the menu.
