Control lock light The button is on the right side of the control panel, it has a lock symbol. It is to prevent kids from tampering with the controls while the machine is on. Depress for 3 secs to lock, again 3 secs to unlock. Of course the machine shd be powered on.
SOURCE: Door is locked! Won't open! Laundry is stuck inside!
If the water has not completely emptied, this wont allow the door to open. Check by lowering the outlet hose into a bowl. If a fair amount of water comes the problem is likely to be a pump blockage
SOURCE: dryer
it's the button that controls the end of cycle buzzer volume /on/off should be small lock image beneath button
SOURCE: Control Lock is on on my washer
The following link explains how to unlock the control panel on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
This is a designed safety feature of the washer that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can be inadvertently locked by leaning on the control panel, or during power outages. The instructions are printed on the front panel of the washer and are included in the owner's manual.
If these steps do not provide you with a solution, you may have a more serious problem than a simple operator intervention. Please let me know if you require additional assistance. I hope this helps you.
SOURCE: to fix the control lock you hold down the control
Holding down the control lock button for 30 seconds did NOT work for me.
I went straight to Whirlpool.com and found that if you Hold down the
END OF CYCLE button for 3 seconds, the control lock turns off and the
washing machine is again operable
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock
problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to
reset the control. Please get back to me if you have any other questions.
Kevin
