Refrigerators Logo
Victor Hoch Posted on Jan 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why would the freezer and fridge temperature indicators flash after a few hours of the unit being switched on?
ptpumpman
Level 3:
Fixya-Fanatic:
Visited the website for 90 consecutive days.
  • Master 408 Answers
  • Posted on Jan 20, 2016
ptpumpman
Master
Level 3:
Fixya-Fanatic:
Answers
408
Questions
0
Helped
76927
Points
1267
Hi, some fridge freezers the indicators flash as they have not got to the right temperature yet. Also some freezers have indicators that will start flashing to let you know that the door has been open to long and the freezer temp has risen.
1helpful
Defy fridge freezer G91641N panel , lights, keep flashing
When the panel lights on your Defy fridge freezer are flashing, it usually indicates an error or a specific condition that needs attention. Here are a few steps you can try to troubleshoot the issue:
  1. Power Reset: Start by performing a power reset to see if it resolves the flashing lights issue. Turn off the fridge freezer at the main power supply or unplug it from the electrical outlet. Leave it unplugged for a few minutes, and then plug it back in or switch on the main power supply. Check if the lights continue to flash.
  2. Check Error Codes: Consult the user manual or documentation for your Defy fridge freezer to identify the meaning of the flashing lights or any error codes displayed on the panel. The manual will provide specific information on what each flashing light or error code signifies and any recommended actions to resolve the issue.
  3. Temperature Settings: Ensure that the temperature settings on the fridge and freezer compartments are set correctly. Incorrect temperature settings can sometimes trigger error codes or unusual behavior. Adjust the settings to the recommended levels and observe if the flashing lights persist.
  4. Contact Customer Support: If the flashing lights persist or you are unable to identify the issue using the manual, it's recommended to contact the Defy customer support or an authorized service center. They can provide further guidance and assistance in diagnosing and resolving the problem.
Alarm showing red and flashing E on fridge temp display - FridgeFreezer model no ARC6680/IX
The high temperature alarm or the red light indicator came on because the internal temp is high. This means that the temperature inside your appliance is still too warm. Keep your freezer/frig door closed and the light will go out in a few hours and you'll then be able to adjust temp or keep it as it was before defrosting.
Best to You
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 • Freezers
I have a side by side samsung fridge which is giving problems for a year now. The fridge start up after resetting the power and gets to the correct temperature in the deep fride and fridge after a few...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Temperature monitor of freezer flashes
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 • Freezers
4helpful
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 • Freezers
2answers
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
2answers
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
