What usually cause the problem of most tagital tablet not turning on
is when the battery is over charged.the maximum time to charge a battery is six hours when bought new.if you dont it will pose some difficulties later.
there are three options
1. get another battery
2. get a booster to boost the battery
3.you also use LED by pinning its cable to the battery,this will take some time.then wait until the light on the LED goes off.it normally takes 3 days before the LED light turns off.
if you have taken these steps the next thing to do is to put the battery back on your tablet and connect it to a power source i mean electric current and see if it will respond to charging.if it works, then you got your tablet back,but if not please get a new battery.thanks
I reset it.. And it comes up but the touch not responding another problem
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
SOURCE: tablet wont charge
Hi It will not charge. Are you sure that the battery is OK? Do you charge the tablet with electricity or via USB? You have checked the cord and wire into the the plug and the plug itself. Is it possible for you to borrow a charger to find out if it is the battery that is not working. All the best Kolbrun
SOURCE: my tablet wont charge or turn on please help
Check its charger. If the charger is faulty, it won't charge the battery. If it is found OK, replace the battery. It is bad.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check the charger first. Plug it into something else. See if it charges. If you can not do that take it to a store like best buy and see if the have a replacement charger that you can try. The plug in the tablet can come loose if it is dropped while plugged in and if that happens you are in the market for a new one.
SOURCE: My supersonic sc-1007jbbt 7inch tablet will not come on, what can I do?
make sure that your charger works. one way that you can do that is to test the voltage with a volt meter. I have one and basicly I had to let it charge for about 8 hours when I first got it. still seems like it takes a long time to charge. just a thought.
