The television comes it has sound but no it shows no picture. try changing input or source
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
TV Has Sound But No Picture Troubleshooting Guide ..... How To Fix Samsung LCD TV - Samsung TV Repair (Blank Screen) - Duration: 9:21.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little ... How To Fix Samsung LCD TV - Samsung TV Repair (Blank Screen) - Duration: 9:21. ... Defective Samsung PS51D550 Plasma (no picture, has sound) ...
Samsung LCD TV screen went black (audio on, no picture) - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - My 46-inch Samsung LCD TV screen went black as I was watching football. ... I can hear my Wii and my TV channels, but can see nothing. ... Sound is good.
tv seems to turn on but no picture?
Jun 11, 2015
LG Plasma Flat Panel 42PC3D - No picture just sound
Jun 11, 2015
Samsung smart tv - sound but no picture
Jan 5, 2013
Samsung LCD 46" tv (LN-T4661F) - No Picture but with sound ...
Nov 12, 2009
More results from www.cnet.com
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
Kolbrun
Try replacing the tcon board on it. Iys on youtube and very easy to do. Check the shopjimmy.com videos for your model # tv.
