Jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
SOURCE: JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
SOURCE: When the JVC LT-26X525 TV is turned on the picture
Either the 24vdc power supply problem or the backlight inverter board problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
SOURCE: CAfter the JVC model LT-42E910 is on for 10
It is a new tv.Take it back where u bought it and trade it in for another tv.This tv have those 2 LCD long inverter boards have problems.These 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the tv LCD screen to produced a picture.
SOURCE: I have a philips 37" flat screen TV, when I switch
hi,
There is problem with the back light of your tv. In LCD tvs CCFL are used as back light to give light to independant pixels. CCLF lamps required high voltage to light. This high voltage is provided by the inverter board inside ths tv. If any one of the chopper transformer (high voltage transformer) have some problem then the inverter will shuts off itself preventing damges to the power supply.
You have to check the 24V from the power supply. If its ok the you have to check the inverter board.if avilabe replace the same. if you are not able to do the same i will prefer to consult some one experienced in it. Back light inverter board will look like one in the picture.
ok
Testimonial: "Well done to Ajin G and thank you. It was an inverter board problem. I replaced both the master and the slave and my TV is good again. Thanks again"
