Head phones will work on other devices
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: My Sony KDL40XBR4 Bravia TV sounds keeps cutting in and out
Sounds like you have a bad Y sustain board, But if you want to part it out, I will by the screen from you and can offer $200 Dollars
E-mail me helpmycomputerfast yahoo com
Just add the at sign
SOURCE: I purchased a Sony Bravia
I believe you have entered Access PIN for the network but check at the same time if you have entered user name password for your internet service provider.
Reply if you are able to resolve the issue
SOURCE: problem using headphones 3.5mm output with Sony Bravia tv
Sony Bravia Model No.KLV-32BX300 LCD TV is with me but i cannot take the audio out from the TV. I undertand that there's an audio output which I don't understand. This may sound a bit stupid that a tv does not have audio out but yes it is! I tried to google about this and no one seems to be able to fix this. So anyone here has encountered this problem before or using the same model and has solved the problem? I seriously wanna connect my speaker to the tv as I'm connecting to my Home theatre system
