Question about Ariens Lawn Tractor 42"" Riding Lawn Mower 936051"
Motor quit put new gas, charged battery, checked oil still does not turn over- prior to this the engine would backfire prior to starting- I have checked connections-
    New Friend:
  • 28 Answers
Does not turn over or does not start? Does not turn over usually means a bad battery or starter. Or connections which you have already checked. There may be a fuse block or inline fuse as well. Does it have a manual pull start as well? Does this turn over the engine or is it siezed up, low/no oil.
Turns over but does not fire usually is spark or the fuel. Back firing would guess spark plug or carberator (air fuel mixture) If it turns over but does not fire, try putting in some Seafoam fuel system cleaner. This will get the varnish-gunking stuff out of the carb. Mix in your tank, turn over quite a bit to get it pulled into your carb bowl and into some of the carb port holes. Let it soak a while and then turn over again every so often to pull in new cleaner. If it starts at some point it will stink a little while burning the cleaner in the tank.
Make sure you have check the old fuel lines and and air vacuum lines for pin holes and cracks as well. Change the plugs. Make sure the air filter is clean. Change the fuel filter. Does it fire if you shoot starter fluid in the carb air intake, this would suggest a fuel issue, such as dirty carb, bad fuel line or fuel filter, or fuel pump.
Posted on Jan 09, 2016
6ya staff
SOURCE:
Bike is starting and backfireing,cant give any gas or it will die. this is be couse of lack of gas fro secondary ?
Hi, Michael and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Won Start Just Turns Over And Backfires Fixed
Engine won start backfires out the exhaust
Bike won start just turns over and backfires Any ideas CBR Forum...
Loud bang backfire when starting cold
my bike backfires but will not start Honda Motorcycles FireBlades org
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 16, 2017 | GAS Motorcycles
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
I have a 99 suburban GMC454 it is always ran very well until I let it sit for a while and the battery died I just replace a starter a month prior to the battery dying we had a cold snap so I took my other...
You may have internal engine damage . broken cam or can.. try to turn the engine manually with a wrench to see if there is any problem while rotate it. In the cold weather when you start engine especially been sitting for too long, engine part need to be lubricated fast otherwise damage it will occur. check and smell the engine oil for strange condition
Feb 03, 2013 | Cars & Trucks
How to find out if loud knocking is piston or thrown rod, plus battery will not stay charged. This all happened after backfire and blown muffler
The only way to determine what it is would be to remove the sump from the motor, Either way you need another motor as the cost to repair will be greater than the cost to replace.
Mar 10, 2012 | 1997 Jeep Grand Cherokee
99 kawasaki ninja EX250 motor swap for a 98 NINJA EX250 MOTOR
I would try charging the battery. Take it off and put it on a slow trickle charge overnight. Batteries usually only last 3-4 years if it is an acid battery.
Nov 27, 2011 | kawasaki Kawasaki Ex250f11 Ninja 250r...
2004 Chevy Suburban quit running after oil and filter change. Took it for a test drive and then it quit running. After this happened, I noticed the oil was dripping out. Replaced the oil and filter again...
SOUND LIKE OIL GOT LOW ENOUGH TO LOCK UP THE ENGINE.THE ONLY THING YOU CAN DO IS TRY TURNING ENGINE WITH A LARGE SOCKET 1/2 SOCKET AND 1/2 SOCKET WRENCH.IF MOTOR WONT TURN ENGINE IS LOCK UP FROM LACKING OIL IF ENGINE DOES TURN AFTER USING THE SOCKET THEN.USE A CODE SCANNER TO CHECK WHAT CODE SETTING OFF REDUCE MOTOR POWER.
Mar 20, 2011 | Chevrolet Suburban Cars & Trucks
I have a 1997 honda CBR .. I put two new spark plugs in it and just bought a new battery and it will not start up! It just backfires when you crank it up! The battery is fully charged. I don't know what...
Have any more details?
How long has it been sitting? How old is the gas? Have you checked that your are getting a spark from the plugs? Gas turned on?
Cheers,
Jan 06, 2010 | 1989 Honda CBR 600 F Hurricane
Hi harley road king been not used for couple years drained put new fuel and new battery on still no go ,, help
Did you add gas additive and run motor prior to storage? If not Gum in carb could be the problem.If it won't kick over it's either gas or spark.Make sure the battery is fully charged,I have used starting fluid to start hard to start bikes with good results.Use Caution Read Directions.Good Luck
Sep 04, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
Will not run
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There may be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw, (sticks out from side of carb perpendicular to the carb throat).
If you are smoking that badly, loose the gas in the tank and start fresh with a 32/1 gas/oil mix. That equals 4 ounces of TWO STROKE OIL to one gallon of gas. Do NOT use motor oil in the gas. It may continue to smoke for awhile, until it rids it'self of built up oil in the crankcase.
On the clutch, be sure the oil level in the gearbox is correct. This is where 10w40 motor oil goes. Check the clutch cable linkages. One at the clutch lever and possibly one at the motor. You should have about 1/4" play in the clutch handle before the lever starts actually pulling the clutch.
You can download a free PDF service manual from this site > >
http://www.carlsalter.com/motorcycle-manuals.asp I checked and your manual is on the list.
Please rate this solution. Thanks!
Apr 11, 2009 | 2005 KTM SX 125
Mk1 Cortina engine starting problems
All fords were notorious for starting at one bit but on the Cortina
that I had one winter I had to remove Two spark plugs from 1 and 3 cylinder , take them in the house warm them up on the gas ring then on return to the car pour in a half spoonful of petrol to the "pots" then refit the hot plugs then after 3 swings she would go. The only other solution was to put the car in a nice warm
garage.!!
Jun 15, 2008 | 2000 Ford Contour
Ariens Lawn Tractor 42"" Riding Lawn Mower 936051" Logo
118 people viewed this question
Top Ariens Garden Experts
enb54
Level 1 Expert
Mike
Thomas F. Schneider
Are you an Ariens Garden Expert? Answer questions, earn points and help others
