Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series Logo
How to fix lcd samsung tv that has no picture but sound?
My tv has no back light, but audio. I've done the flashlight test and i do see a menu bar, so i changed out both the tcon board and the main power source but still same problem.
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Mar 14, 2008
SOURCE: lns4692d no picture
No it is the little board underneath the metal container at the top middle of the panel..the very top.
-Josh
Anonymous
  • Posted on Nov 19, 2008
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Anonymous
  • 304 Answers
  • Posted on Apr 16, 2010
SOURCE: Hello, I have a Samsung LN-S4692D.
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
Rick Beach
  • 59 Answers
  • Posted on Jan 24, 2015
SOURCE: how to fix TV
If you are willing to take a chance...and you have some technical skills you may be able to repair it. I was able to replace 2 capacitors on my power board for under $5. I had no picture, no sound. Not saying that is what is your problem. Search the internet for your model number and no picture. I see several youtubes on yours as well.
Testimonial: "Thanks Rick, it's great that you were able to fix your TV for $5. I do not have technical skills, but will keep trying to watch videos to try to figure it out. If I get enough courage, I will try to open the back panel. Where did you get the capacitors?"
skippy101
marco amezcua
  • 143 Answers
  • Posted on May 30, 2015
SOURCE: I got a 55 inch Samsung flat panel tv model # UN55D6000Sf Version H302 with standby light blinking 1 time in repeat. I have changed the power supply board, main board & tcon board but still no luc
since you have replaced the main parts in the tv already it is safe to say you have bad led strip these can be tested with a 12v dc power supply
My samsung 62" tv has no picture/have sound
Darken the room. Very dark. Turn tv on. Press menu button. Get flashlight and shine at screen. If you can make out the menu barely. It's the back light gone. Is it plasma or lcd.
1helpful
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
1helpful
I have a samsung ln40b500p3f that has sound and no picture. You can turn the tv on and the picture will flash on and off about three times then stays off but I still have sound.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung LN46C670 LCD TV not displaying picture
There is a good chance that the actual back lights are not working. This could be due to a number of things. The troubleshooting guide is here: http://www.toms-service-manuals.com/?do=search&mfg=Samsung&modelsrch=LN46C670&typekey=0&Search=Submit+Query
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Turned on, has sound but no picture. Why?
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little ... +ducksfans76 have you done the flashlight test? what that is is turn the tv on in a ... screen that means your backlight is out and with LCD tv's most likely is the inverter. ... Samsung Flat Screen No Picture Only Sound 002 - Duration: 1:26.
Repair A TV With Sound But No Picture - YouTube
? 2:30
https://www.youtube.com/watch?v=MQj2t4nNVYc
Sep 18, 2012 - Uploaded by MonkeySee
Learn how to troubleshoot your television if you've got sound but no picture. ... I have a logik lcd tv and for some reason thescreen always turns ...
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
