Delsey Helium Shadow - 25 Trolley Luggage : One Size Logo
J
Judy Stahr Posted on Jan 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset built in lock on my Delsey Helium suitcase
How to reset the built in lock?
Jorge Luis
Level 2:
Sergeant:
  • Expert 198 Answers
  • Posted on Jan 07, 2016
Jorge Luis
Expert
Level 2:
Sergeant:
Answers
198
Questions
Helped
50802
Points
609
The default combination of new lock is always 000..If you forgot the correct combination, it is not possible to reset it.
My delsey combo lock won't lock?
If your Delsey combo lock won't lock, there are a few things you can try to troubleshoot the issue:
  1. Check the battery: Make sure the battery in the lock is not dead. If the battery is low, replace it with a new one.
  2. Check the lock's alignment: Make sure that the lock is properly aligned with the suitcase zipper. Sometimes the lock may be slightly off-center, which can prevent it from locking properly.
  3. Check the lock's mechanism: Make sure that the lock's mechanism is not jammed or damaged. If it is, it may need to be repaired or replaced.
  4. Check the lock's code: Make sure you have entered the correct code for the lock. If you have forgotten the code, you may need to reset the lock or contact the manufacturer for assistance.
  5. Clean the lock: Sometimes dirt and debris can accumulate in the lock mechanism, preventing it from functioning properly. Clean the lock with a soft cloth and mild soap.
  6. Check the suitcase: Make sure the suitcase is not damaged in any way that can prevent the lock from closing properly.
If none of these solutions work, it may be best to contact Delsey customer service for further assistance. They may be able to provide additional troubleshooting steps or may suggest to get the lock serviced.
I recently took my "Delsey" suitcase out of storage and can't find the combination to the 3-digit, built in to the luggage between the key lock hasps. How can I reset?
Your adjustable TSA combination lock as delivered can be opened with the combination 0-0-0. To change the combination:
1. Open the lock by entering the factory code 0-0-0.
2. With a pencil or something pointed, press firmly on the Reset A button until you hear a click. Keep it pressed down.
3. Enter your secret code (for example 8-8-8) by turning the wheels.
4. Push button B so that button A goes back to its original position.
Your code is now registered. Write it down in a safe place so that you can go back to it if you forget it. If you want to change the combination, repeat steps 2-4.
My Delsey shadow 21” luggage just arrived and is locked. I tried the 000 combination but still can not open it. What do I do?
Contact form on the web site to reach the manufacturer which mentioned 0 0 0.
Someone may have accidentally changed the combination.
If patient, could try 001 through 999 to see if any combination works.
https://shop.delsey.com/delsey-tips/post/2016/8/8/locks-and-codes-all-you-need-to-know/90
LOCKS AND CODES ALL YOU NEED TO KNOW
How do I reset my locking code?
There must be the instructions to follow.
How to unlocked my 3 digit bag delsey
Give your bag to a young child with the promise of a gift, hey presto + will keep the child busy for ages.
2answers
I forgot my delsey luggage combo can i still open it?
Go to a luggage repair shop and they can likely do that for you. If not then a locksmith
How can I reset tsa lock on Delsey shadow luggage?
Ahh, you will have to try all 999 different combinations.
13helpful
I locked my Delsey suitcase and now i don´t know how to unlock it. I need urgent assistance
if it is a combination lock and you haven't set it yet the combo should be 0000
Top Delsey Luggage & Travel Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Delsey Luggage and Travel Expert? Answer questions, earn points and help others
