Garden Logo
E
Edward J Putt Posted on Jan 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't start my mower after replacing fuel filter
Ted Maxwell
Level 3:
  • Master 3,519 Answers
  • Posted on Jan 07, 2016
Ted Maxwell
Master
Level 3:
Answers
3519
Questions
Helped
724766
Points
11729
Hi Edward: Try this; Remove air filter from carb. Toss in a thimble full of gas. Start. That bit of prime should do it. You may need to repeat. My Craftsman has needed this for cold starts ever since new
How do I fix my mower
Sounds like the carb is dirty. if your carb has a fuel cup on the bottom of the carb remove it and clean it real well as well clean the fuel jet as well. a dirty fuel jet will not let the right amount of fuel to give it power. Make sure you have clean gas and the air filter is clean.
Apr 25, 2016 • Garden
1helpful
Where is the fuel pump on the Briggs & Stratton engine on this mower? Thanks
unless its a briggs I/C engine(orange) or a vanguard V twin (these use a vacuum driven pump) it doesn't have a fuel pump all it has is an inline fuel filter the fuel tank is just slightly higher than carb (gravity) , now it does take a special type of fuel filter (gravity type) and just any filter will not work , id use the factory replacement filter , briggs sells em lots of places
Push mower starts then dies
Possibly replace air filter . Check fuel is actually coming through carburetor. Check there is no dirt in fuel line or fuel tank. If old "dead" fuel renew with fresh fuel. Check spark plug lead is in good condition. As mower starts and then cuts out problem most likely to be fuel starvation. Hope these suggestions help.
Oct 19, 2014 • Garden
Free craftsman manuals
First, drain the tank by removing the metal clip from the fuel line. Remove the air filter. Then remove the 3 bolts retaining the air filter holder. You will see the fuel line and the fuel filter. Squeeze the metal clips that hold the fuel line to the filter, and slide the line off. Replace filter with new one and reverse the process.
This is for a push mower. Good luck! Hope this helps.
Aug 18, 2014 • Garden
Yardpro mower wont start
If you left fuel in your machine for any amount of time I would consider a carb cleaning. Did you hit anything last time you mowed?
If so you may have sheared your flywheel key which times your engine. This will also cause a no start condition
Aug 09, 2014 • Garden
Mower Hard Start/Not Cranking Up
Hard to start could mean a lot of things. Has the amount of pull required changed? IF it has then it might be something related to increased friction on the crankshaft. You either have spark or you don't. If you do then of course you need to change the gas first.
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
Here are a few tips to look at, I would first check your inline fuel filter to make sure its not clogged up. See Page 26 of the Manual for additional help.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_NAen/HUSO2010_NAen_YTH2348_532441716.pdf
PROBLEM
Will not start
CAUSE CORRECTION
1. Out of fuel. 1. Fill fuel tank.
2. Engine not "CHOKED" properly. 2. See "TO START ENGINE" in Operation section.
3. Engine flooded. 3. Wait several minutes before attempting to start.
4. Bad spark plug. 4. Replace spark plug.
5. Dirty air filter. 5. Clean/replace air filter.
6. Dirty fuel filter. 6. Replace fuel filter.
7. Water in fuel. 7. Empty fuel tank and carburetor, refill tank with fresh gasoline and replace fuel filter.
8. Loose or damaged wiring. 8. Check all wiring.
9. Carburetor out of adjustment. 9. See "To Adjust Carburetor" in Service Adjustments
section.
10. Engine valves out of adjustment. 10. Contact an authorized service center/department.
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
1helpful
Lawn mower won't start
Did you set the plug gap to specs?
Check fuel line filter.
Empty gas a replace with fresh fuel.
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Top Garden Experts
Jay Finke
Jay Finke
john h
