The most likely cause of this issue is a problem with the washing machine's door lock. When the door lock is not functioning properly, it can cause the wash and start lights to flash. To fix this, you will need to replace the door lock.
Had a similar problem ,flashing red led means door not locked, I
removed door from machine removed front from door and found hinge pin
for lock had come adrift, religned pin and chapped back into position
.THen replaced door and door to machine .dor shut and lock worked
perfectly, hope this helps If this doesn't work you may have to replace the EMW. Should cost you around 60$
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
This depends on how old your machine is mine is now 7 years old so I do not want to invest in long term soltions. So I repaired my own, I bought a new interlock and replaced the old one that did not work. So I shorted out the three links that go to the interlock, the machine now shows the lock is always on and you can open the door during the wash cycle so BEWARE. Also if you have never wired a plug or fixed basic electrics DO NOT DO THIS.
1. Turn off power and unplug. (Very Important)
2. Remove lid you will need torx drivers.
3. Unscrew door interlock from the front of the machine.
4. Lift out interlock. Try replacing the interlock with spare first (about £15).
5. If new interlock does not work do the following.
6. Put Interlock back on without wires attched to it.
7. From car spares shop buy spade conectors and create a three way shorting link (insulate well).
8. Put shorting link into each of the wires that go to interlock.
Safely tie up wire to a loom (do not let dangle)
9. Shut the door remove hands and try starting the machine.
10. If that works put the machine back together. And warn people that the DOOR CAN BE OPENED DURING WASH CYCLE and STARTED WITH DOOR OPEN. So check when the machine has stopped properly.
