Cannot change 12 hr to 24hr
SOURCE: Change watch setting from 24 to 12 hr clock
my 40/6703 has 4buttonstop left-light topright-st-stp bottom left mode bottom right reset can u help
SOURCE: change time to 24 hr from 12
Go to:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Full user manual and instructions there to download.
SOURCE: How do I switch from 24hr mode to 12 hr mode?
Check out the manufacturers web site, some manufactureres have users manuals for their watches which can be downloaded. You may be lucky. You could also try some of the various manuals websites. They have manuals for all manor of things. Good Luck
SOURCE: KC 3982 how do I
kc 3982 Hold the top right button, then push once the bottom left button. That should do the trick.....I just got the same watch, Do you know how to change the time?
SOURCE: Need to set time for zooyork zy1035/s60-12
They all work pretty much the same, once you get use to setup you can figure it out on any. Here is a link below
http://www.genevawatchgroup.com/wp-content/uploads/2012/12/Zoo-York-Digital-Watch-Instruction-1.pdf
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
