Sony DVP-SR200P DVD/CD Player Logo
Douglas Bays Posted on Jan 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i program my sony dvd player dvp.sr200p to work on my philips tv
starvin
Level 2:
Novelist:
  • Expert 208 Answers
  • Posted on Jan 01, 2016
 starvin
Expert
Level 2:
Novelist:
Answers
208
Questions
0
Helped
61233
Points
421
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Testimonial: "have done this there was a code from before when i first bought it so i could use it to for volume and trun tv off and on"
1 Related Answer
A
Anonymous
  • Posted on Jun 05, 2008
SOURCE: Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Need to no how to make my Sony DVD player remote work the volume and power on my Philips TV
Does the remote have a TV setting? In other words, is there a setting on the remote where you can go back and forth between TV, DVD, Cable, etc? If not, you cannot use it for that purpose. If it does, try setting up your remote with one of the following codes.
11454, 11054, 10690.
How to set up remote control so it will work volume and power on my philips tv the sony player i have is a dvp.sr200p
Why not use the Phillips remote to control the DVD instead of the reverse?
The Sony codes are listed below.
20533, 21533, 20864, 21033, 21070, 21431, 21536.
How do i program the remote for my DVP-sr200p/o dvd player to my tv
Is there a switch on the top of the remote for tv? Switch it to tv and consult the Sony manual for programming to your tv. Or esupport.sony.com
1helpful
Hooked up dvd sr200p to bravia..no color...
If you are connected useing the component video cords (red,blue,green,red,white) it sounds as if you have the red,blue or green cords connected to the wrong color of jacks on the back of the TV or the DVD player, recheck your connections.
If all is good there, maybe one of those cords are bad?
The Sony DVP-SR200P DVD player is on the bottom end of their model line up, and you may have received a bad one right out of the box!
GOOD LUCK !!
10helpful
3answers
I need to unlock the DVP-SR200P to play all regions.
Tell that to my DVP-SR200P ¬_¬
I just bought it, It's regoin 4 and it doesn't play other ones.... I just found out!!!!!
MONIQ
7helpful
How to turn off the closed captions on my sony dvd player model (DVP-SR200P)
I had the same problem so i simply turned off the CCD on the tv itself and no more captions!
47helpful
2answers
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
