I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
